Attached is a short newbie manual for ViewPort (Tips and Best Practices)
I am/was a new user of ViewPort.· As happy as I am now with the program, I had some early struggles with learning how to use ViewPort that motivated me to write the attached manual.·
This project was undertaken with the help and oversight of Hanno Sander, the author of ViewPort, ·in hopes that it might smooth the way for other new users·as they familiarize themselves with this powerful and downright fun Spin code debugger.
This not a subsitute for the main manual.· The key point is that it is organized around the kind of issues that new users encounter, so it·should be quicker path to find answers to common problems.
I hope this helps someone.
PS: Hanno is posting this on his site as well.· He suggested that I post to this forum.
Note: Windows will protect you from opening a .chm file accidentally.· If you don't "unblock" the file, it won't let you see the contents.· The following link will explain that process for those that are unfamiliar with the procedure.
Unblock .chm file...
http://www.west-wind.com/weblog/posts/581253.aspx
Post Edited (Bob Anderson) : 11/16/2009 6:33:05 AM GMT
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
JMH
Suggestions?
Jim
All I have to do is uncheck the box that says "always ask before opening this type of file".
The link I included is the most comprehensive I've ever seen.· That's the best help I could provide. (Actually, the link was given to me by Hanno Sander.)
