What's the weakest link?
In my experience, many connection problems that occur with the Propeller Tool and ViewPort can be traced down to a poor USB cable. The "retractable" USB cables that Parallax supplies with the PropPlug are particularly problematic. Lately, one of my customers has had problems with his mouse when he used a 14 foot USB cable to connect to the Propeller.
I'm not saying we should all run out at buy "Monster" usb cable, or non-oxidizing 100% gold plated connectors. However, if you experience connection problems, try using a "standard" USB cable- in many cases your problem will be solved.
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
Hanno
Thanks for this info, Hanno. Hopefully our cats won't be the cause for problems, though they love chewing anything small.
Harley Shanko
I now use a non-retractable cable for connections that must stay connected for a long time.
A 4-conductor ribbon cable works fine for me as long as I keep the length under 10 feet.
JMH
Hanno
