Issue writing buffer to SD Card
ry.david
I am trying to get some quick and dirty code put together for an event tomorrow. I have another piece of code that pumps the current buffer information out over serial with no issue. However I am having troubles writing that same data to a SD card. I verified I can write to the card using pputc, and the FSRW speed test works without an issue. I created 'TempBuffer' that was defined with the type of data I was expecting. Filling it with '4300.9421' writes '3D D6 1C 38 34 35 99 81 C1' which does not correlate. I added the relevant code below. Thanks in advance!
VAR BYTE GPSTime[noparse][[/noparse]10], GPSValidity, GPSLaditude[noparse][[/noparse]9], GPSNorS, GPSLongitude[noparse][[/noparse]10], GPSEorW, GPSSpeed, GPSTrueHeading, GPSDate[noparse][[/noparse]6] BYTE TempBuffer[noparse][[/noparse]9] LONG GPSStack[noparse][[/noparse]100] 'Adjust later PUB Main dirA[noparse][[/noparse]RELAY0]~~ dirA[noparse][[/noparse]RELAY1]~~ dirA[noparse][[/noparse]RELAY2]~~ TempBuffer[noparse][[/noparse]0] := "4" TempBuffer := "3" TempBuffer := "0" TempBuffer := "0" TempBuffer := "." TempBuffer := "9" TempBuffer[noparse][[/noparse]6] := "2" TempBuffer[noparse][[/noparse]7] := "4" TempBuffer[noparse][[/noparse]8] := "1" 'waitcnt(clkfreq + cnt) 'Wait GPS to start up, it will freeze if initialized too early Serial.Init Serial.AddPort(MAIN_COM, MAIN_RX, MAIN_TX, -1, -1, 0, 0, MAIN_BAUD)'Set Up Main Communication Port Serial.AddPort(GPS_COM, GPS_RX, GPS_TX, -1, -1, 0, 0, GPS_BAUD) 'Set Up Port For GPS Serial.Start Cognew(GPSDecoder(GPS_COM), @GPSStack) waitcnt(clkfreq + cnt) outA[noparse][[/noparse]RELAY0] := 1 SD.mount_explicit(SD_DO, SD_SCK, SD_DI, SD_CS) SD.opendir SD.popen(string("log.txt"), "w") repeat 1 SD.pwrite(TempBuffer, 9) SD.pclose SD.unmount outA[noparse][[/noparse]RELAY0] := 0 PUB GPSDecoder(Port) | a, temp Serial.rxflush(Port) repeat if Serial.rx(Port) == "$" a := 0 repeat until Serial.rx(Port) == "," 'Wait for GPRMC ID to clear repeat until (temp := Serial.rx(Port)) == "," 'Collect Time Stamp GPSTime[noparse][[/noparse]a++] := temp repeat until (temp := Serial.rx(Port)) == "," 'Collect Track Validity GPSValidity := temp a := 0 repeat until (temp := Serial.rx(Port)) == "," 'Collect Laditude GPSLaditude[noparse][[/noparse]a++] := temp repeat until (temp := Serial.rx(Port)) == "," 'Collect North Or South GPSNorS := temp a := 0 repeat until (temp := Serial.rx(Port)) == "," 'Collect Longitude GPSLongitude[noparse][[/noparse]a++] := temp repeat until (temp := Serial.rx(Port)) == "," 'Collect East Or West GPSEorW := temp a := 0 repeat until (temp := Serial.rx(Port)) == "," 'Collect Speed In Knots GPSSpeed[noparse][[/noparse]a++] := temp a := 0 repeat until (temp := Serial.rx(Port)) == "," 'Collect True Heading GPSTrueHeading[noparse][[/noparse]a++] := temp a := 0 repeat until (temp := Serial.rx(Port)) == "," 'Collect Date GPSDate[noparse][[/noparse]a++] := temp
General things:
- what version of fsrw are you using?
- I don't understand what the "opendir" call is doing
- you may wish to trap the return values of the calls to see if anything is returned (ret_val := \sdfat.etc)
Jonathan
edited to make the abort trap slash go the correct way (i.e. \ instead of /)
lonesock
Piranha are people too.
Post Edited (lonesock) : 11/13/2009 7:54:00 PM GMT
Jonathan
lonesock
