Melexis 90217 Hall-Effect and Basic Stamp
Only to know about the
maximum distance between this sensor and the Basic Stamp.
I understand that voltage drops with distance. For this reason
cables must not be too long.
Thanks, Joe
Thanks, Joe
- Stephen
I am not an expert , but I planed to connect the sensor to the stamp just
like the pdf page 5 .
There is a kind of connection for severe environment componets ( like the page 5 ) of this pdf :
http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/MLX90217.pdf
The speed is less than 1500 rpm.
But I don't know what kind of code , I am trying to use pulsin.
Thanks , Joe
·Heres a simple test setup for the MXL90217. It could be useful for target distance from hall sensor test.
Use a nonmagnetic iron based target.
Hope this helps
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
