"Say It" module opinions?
I'm considering getting either the "Say It" module or the voiceDirect 2 for my stingray. What are y'alls opinions? Which one has better recognition? Thanks!!!
PC problems? Maybe you should try Linux! Easy, Fast, Free, Customizable, Powerful
Do they use an artificial neural network of sorts? That may explain why the recognition rate goes down as the amount of words increases. If so, could I use it for other applications, like AI?
There are no statistics given, partly because they'd be meaningless. Matches and false matches depend on how similar the words are or are not, how much noise or other artifacts are present, etc.
Read the documentation! Do you see any mention of what chip is used, let alone whether there's access to it other than what's described in the documentation?
Parallax is very good at producing documentation for their products. They have good technical writers and their engineers are also good at producing understandable documentation and it's all available on their website. They also provide links to other manufacturers' documentation when they incorporate those products into their own.
How can we use Bluetooth module and Say it module at the same time as the ports for connecting them is same. Do i have to use breadbroad. Please help me out. And one more thing, if use bluetooth module, can download the program directly to boe-bot , without using USB cable.
Hanmant
