anyone can help me in the easy bluetooth module....plz
wavestorm1986
heloo everybody.....
i bought an EASY BT MODULE, i already detect the signal of the MODULE in my LAPTOP using the built-in BT, and i also detect the signal in my mobile phone.
i tried to connect between the module and the laptop using hyper terminal,after i create the LOINK which was that the BT icon of laptop can indicate that its BUSY..so, when ever i press (AT) in the hyper terminal nothing will appear in the box..........i hit enter i found the LED of the easy BT module is PLINK whenever i hit enter........
i will try to connect the module using RS232 to a PC later, but my problem is any person can explain to me why the connection is there but cant see anything in the box when i press AT???
if i want to send an audio file or a PNG file is it possible from the laptop to the module and to the PC??????
thanx for your help..............by the way i am using labVIEW to detect the signal from the BT module
We can't answer your other question about why it doesn't seem to work without much more information about how you have things connected and configured. Keep in mind that you can't connect the Easy Bluetooth module directly to an RS232 port without possibly damaging the Easy Bluetooth module.
BT MODULE
MAX232 CIRCUIT
DB9
PC????
is that correct?????
