Persistance of vision & max LED's driveable?
Javalin
Hello,
Is there a maximum number of LED's (the 7-segment "8" style) that can be driven using the POV technique of switching them on-off sequentially, but without flicker?
Currently 6 is the minimum I need to drive, but 8 might be better...
James
James
James
James
www.smarthome.viviti.com/build
Thanks for the compliment. I am a bit surprised I have never seen this technique in use anywhere. It makes so much sense when you have a large number of digits to display. I don't see any reason why it can't be used for 14 segments as long as a 7% on time provides the required brightness. I have not used it on 14 segment displays, only 7 segment plus decimal ones. It is also quite flexible in that you can use a shift register, counter/decoder, or similar chip to save on I/O pins when required.
But the supply side, that might need to supply quite a bit of current if it is lighting up 20 or 40 or more segments all at once. So would that need a high current supply side switch - eg a small signal NPN transistor driving something like a PNP BC328?
Post Edited (Dr_Acula) : 11/19/2009 12:52:57 AM GMT
All of the pins for a specific segment on each digit would be connected in parallel, and be connected to the power supply through a "segment select" transistor or driver of some kind. If brightness is to be controlled this is where PWM would be done. As the number of digits goes up the current through these drivers will also increase.
The "digit select" transistor or driver would be where the current limiting is done since only one segment on a digit is lit at any time. Since peak currents through a segment is low (150mA for the one you mentioned) something similar to a TPIC6595 would be a good choice of driver.
As more digits are added the current draw from the power supply and through the "segment select" will get higher, and one or the other will be the practical limit on how many digits are possible.
This is relevant to the original post too. Eg you can have 100 displays. If each segment has a current drain of 20mA then you need a transistor or mosfet that can handle 2A. 14 of these for 14 seg displays, and 7 for 7 segment displays. So still quite possible to do with relatively cheap discrete components. They are the sort of transistors you have on output stages for audio amps. Eg a BC640 is good up to 1A so that could do 50 displays.
There are a myriad of chips out there like the TPIC6595 that do low side switching. I'm not sure if there are as many that do high side. Mind you, it isn't that hard to solder in 7 or 14 power transistors.
Futurlec take 2-3 weeks to deliver but I am going to order some of these displays and do some current vs brightness tests.
The number of segment drivers on the other hand remains constant at 7 or 14 while the current through each driver increases in proportion to the number of digits.
This is particularly nice for driving common cathode leds because you can use something like a TPIC with 8 resistors to drive a group of 8 digits. Use 1 (for 7 segment) or 2 (for 14 segment) TPICS (or '595s) to drive the segment drivers and the number of digits you can drive is quite large (as is the total current).
Imagine using 8 TPICS and 7/14 transistors to drive 56 7 segment or 48 14 segment digits with 3 prop pins.
Post Edited (kwinn) : 11/22/2009 3:29:12 PM GMT
Latches eg 374 are a possibility, but in a way, the HC595 might be the best way to go. Only three pins, but with a propeller, you set up all the outputs, send them out, then light up the leds, but then there is a long delay (relative to a propeller clock cycle) while you send out the data for the next segment. Use that time to send out all the cathode bits. I think it ought to be possible to still run at very high multiplex speeds so no flicker.
First little experiment, how bright is a 14 segment display segment with a 14:1 clock ratio? I hooked up a simple 555 timer and set it to 14:1 and found that at 5V, 220R was still a little dim, but 100R looked good. Looking at the currents, I think that means the cathodes can't go straight into a HC595 and really are going to need small signal transistors. No matter; BC549s or 2N2222s are cheap. Or DIP16 transistor arrays.
So, for a crazy 20x4 display the 14 high side switchers could be switching maybe an amp or more, so that sets the transistors - maybe a TIP32?
www.smarthome.viviti.com/propeller
Mind you, 14 TIP32s is no big deal (I'd drive them with BC549s or 2N2222).
1- It reduces the number of different parts you need to inventory.
2- It simplifies the board layout since you have one long shift register composed of one chip type.
3- The chip is also useful for driving solenoids, steppers, and other small loads that 7400CMOS chips can't handle.
4- Volume pricing.
It has become my chip of choice for small loads beyond what a '595 can handle.
Looking at the spec sheet the TIP32 has a gain of 50, so 10mA on the base switches 0.5A. So there will need to be some sort of amplification on base as 8x10mA would be beyond a 595.
Thinking further, I've been using simple switchers LM2574 for 3V and these have a max of 0.5A, so if that chip was used might need to break it up into groups powered by different switchers. Then you might need different groups of 14 transistors. Hmm, then may as well go for lower current transistors??
OR use a switcher that can give higher currents. Though 1A seems to be the upper limit of many of them as lots of diodes max out at 1A and so do lots of inductors.
And some back of an envelope calcs, 30mA is the current per segment which is 1/14th of the time, so that is equivalent to all segments being on at 30/14 mA or 30mA per digit. So 10 digits is 300mA, maybe you get 15 digits for a 500mA switcher and 30 digits for a 1A switcher.
The TPIC output is an open collector transistor so no pullup is required. The transistor goes from open circuit (0) to fully on (1).
I normally run the displays from the unregulated input voltage to avoid having a high current through the regulator. If you use 6 or 7 volts in and an LDO regulator for the 5V to the TPIC's, and a 3.3V regulator for the prop you can run the displays from the unregulated input. Having the power dissipated over several transistors, resistors, and chips instead of a single regulator makes life easier.
If you are concerned over efficiency you could have a separate switching regulator to provide the exact voltage required to drive the display.
The Sure Electronics HT1632C (http://www.sureelectronics.net/goods.php?id=979) is intended to drive an array of RGB leds but it can also be used to drive as many as 32 7segment displays with decimal points or 24 14 or 16 segment displays. Each display can have 16 brightness levels, and multiple chips can be connected in a master/slave mode to increase the number of displays.
Oops.. here is the forum link http://forums.parallax.com/showthread.php?p=854567
Post Edited (kwinn) : 1/16/2010 4:41:20 PM GMT
The module from Sure is listed at $11.64 for 8x8x6 leds. Comparing with other solutions, eg Prop+PCB+leds or Other Chip+PCB+leds, other solutions come in at least twice the price.
Interestingly, a search for the datasheet comes up with a link at the top of Google that is linked to the Propeller forum http://forums.parallax.com/attachment.php?attachmentid=64974
Scrolling down the datasheet the common pins can sink 250mA which ought to be plenty (there are examples with transistor drivers too)
For dot displays eg 8x8, I think nothing would beat those pre-made modules for value.
Scrolling down to page 11 you can start to see how this could work for other displays besides dot displays.
Thinking aloud here, but say instead of 32 rows you had 4 7seg displays (+dp=8). Join all the commons and you get 4 segments per common, and with 8 commons, as you say, 32 7 segment displays.
Ditto a similar principle with 16 segment displays (though I'm getting a total of 16 characters, not 24).
For a dot display, that pre made module is exceptional value.
For 7 seg or 14 or 16 seg displays, do Sure sell just the chip?
The interesting thing from my point of view was that any of the chips that are now coming out to control an array of leds can almost certainly be used for driving segment type displays as well. I will certainly keep this type of chip in mind if I need to build a new display board.
