Speech recorder and BS2
Hi Dears,
in my classrom I would like to use a BS2 in a meteo station where after reading the sensors a voice tell you direction and speed of the wind.
Did you esperienced it?
What kind of audio format do you put in the eprom and how?
Thanks a lot.
Marco Moretti.
Thanks a lot.
Marco Moretti.
1) There's not enough memory.
2) The BS2 isn't fast enough.
The QV606m1 from Quadrovox can do what you want (www.quadravox.com/frameset/qvframeset.htm).
The VMusic2 from Vinculum can also do what you want (www.vinculum.com/prd_vmusic1.html).
The BS2 can very nicely act as a controller for either of these devices. I've used the VMusic2 and the older QV306m1 with a Stamp. The QV606m1 is more responsive (for selecting individual words and phrases) and has a built-in audio amplifier. The VMusic2 uses a USB memory stick which can be loaded up using your PC. Both devices use MP3 files.
www.robotshop.ca or www.robotshop.us
Product code : RB-Rog-05
verry easy to use.
You can also use a small sd-disk to store text file.
I will post an exemple soon.
