Rigid shaft Coupling question
About a year ago I came across a coupling sleeve or insert to reduce the bore on the other end of the coupling and now I cannot, for the life of me, remember the name of the item.· The rigid coupling that I am using is 1/4 on both ends, but I obviously need a smaller diameter on the other.· I know they exist, but my extensive search is yielding no results.· Can anyone help?
http://www.grainger.com/Grainger/bushings/ecatalog/N-apv/Ntt-Bore+reducer?op=search&sst=All
