Using a prop pin to do pwm on a fet
I need to pretty much make an H bridge, i have a prop pin rigged up and switching the led on, but the led is really dim, i have tried switching out the series resistor for the led but it doesnt make any difference. i am only using one fet on the H bridge because i will only ever drive the motor in one direction. the circuit is wired up exactly as this site shows except for the switch is coming from a high signal on the prop pin (http://brunningsoftware.co.uk/FET.htm) any help with getting this to work would be greatly appreciated
Anyway, your FET needs to have a low gate threshold, usually referred to as logic level gate drive. Your description also seems at odds with the link so maybe you should just attach an image of the circuit as you have it hooked up.
BTW, use the URL button to start a URL and end it so that it is clickable like this
*Peter*
Here's one example of an MOSFET that will switch up to about 3A with a gate voltage as little as 3V:
www.fairchildsemi.com/ds/FD/FDFS6N754.pdf
@geek You are better off using a bipolar npn in that circuit. Another MOSFET you can use besides the one Mike mentioned is the IRF3708 which will work well at 3.3V gate driver and handle more than enough current.
*Peter*
