RESOLVED thanks to the forum: RS232-Using Hyperterminal
I have a program which I have verified the serial comm using the USB Plug & FullDuplexSerial & Hyperterminal and it works perfectly.
There are about 15 lines of setup information sent upon boot and hyperterminal displays this with no problem again using the USB.
Now I am trying the 3 transistor RS232 configuration shown on the Parallax site and I can successfully load RAM and verify, load EEPROM and verify however when using hyperterminal I get nothing displayed after boot when again it should display the same 15 lines of setup info.
I am not changing the program between the two comm setups. I did however, play with all 4 modes of FullDuplexSerial with no positive results. After downloading the program using the RS232 setup, I went back to the USB plug to verify that the program was still working and sending the setup info.
I have Hyperterminal set to comm1, 9600, 8,n,1 and I have played with all flow options none of which work. I am using the VT100 emulation with the default settings just as I did with the USB connection.
It would seem the Propeller IDE has zero problems communicating over this 3 transistor setup yet something in Hyperterminal is not set right.
I have a series of LEDs on some clock, strobe, data lines that verify I have passed the setup information in the program and that the required cogs are running.
Post Edited (Wurlitzer) : 11/6/2009 1:45:46 PM GMT
*Peter*
Thanks again Peter.
Craig
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
Craig
I've got an old-school dos batch file that runs BST to compile a program then runs teraterm ready to talk to the prop. So compile/run is a single step operation. Teraterm does change the DTR line when it boots and resets the prop, but that doesn't matter as it comes just after a download anyway.
www.smarthome.viviti.com/build
Post Edited (Dr_Acula) : 11/6/2009 5:03:31 AM GMT
However, the Parallax Serial Terminal works without grounding DTR and is a much nicer interface than Hyperterminal (should have know Parallax would do a better job).
I have used teraterm in the past and as I recall it was a very nice tool also.
In any event thanks to everyone as that completes this project.
Craig
Does anyone actually know exactly how the PST avoids the reseting (DTR) problem. It does not require the
grounding of the resistor or anything.
How is it that it upon starting it stops the DTR from going High then low when it release the posrt
which resets the propeller???
I would appreciate the knowledge...
Samuel
