Infrared detector in place of a phototransistor ??
charlieknox
Can I use the infrared detector that comes with the Boebot, coupled with an infrared LED, in place of a phototransistor & light source, for detection of an object breaking the beam?· The application is in a "jam detector", as in a photocopier, that would have 3 horizontally spaced stations with a gap (vertically) between the IR LED and IR detector.· If 2 adjacent detectors sense paper (the beam is blocked), this signifies a jam - if not, all is well.· I know the IR LEDs & detectors are used with the Boebot in a reflective mode.· Can I use them with the LED pointed toward the detector, and when the beam is broken, the detector output changes state?· Thank you for any light (IR or otherwise) you can shed on this.
Charlie·
Charlie·
- Stephen
So yes, you can do this, assuming the paper isn't transparent to IR light -- which I'd be amazed if it was.
Charlie
