cpld reusing JTAG pins
mctrivia
anyone know best practice if you need to use every io pin for io even the jtag pins?
should i set the jtag pins as outputs? how would you go about programming it if you did?
I am curious because the EPM7032AETC44-10 is really cheap and has 36 IO the exact number i need. Don't think there is enough program area though but it made me curious.
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
