Shelf life of semiconductors held in a storage area for 26 years question
My dad stored some semi-conductors in a storage area for about 26 years.· The storage area was not climate controlled and some things melted and other parts look okay.
I plugged in a flood light and it didn't last half a day.
Some of the things like wires, solder and terminal connectors I will keep.· Should I try everything else or should I say enough is enough and give up with the capacitors, resistors and other things and just go with new?· If something looks okay, will it give me a true voltage or could its characteristics change over time?
Electrolytic caps - toss - The electrolyte dries out and even if they seem to work now they may not work for long.
Other capacitors, Resistors, IC's, Transistors, Diodes, Zeners, Bridge rectifiers, Relays, etc search the internet to see if you can find data sheets for them and keep them if they may be of any use. Test them before soldering them in a circuit.
Beau Schwabe
IC Layout Engineer
*Aluminum wire recycle it will not be worth your time to clean and you can make a little money on the raw metal.
*Copper wire will be fine though insulation on cheap older wire can be a pain to take off.
*Resisters, Caps - odds are the parts are cheap enough to buy to not be worth your time and effort to test and more time and frustration to trouble shoot later if a bad one gets into a circuit.
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
