PINK / Javascript question
Tumbler
Hello
The html page below is my pink index page.
As you can see, it shows 4 switches, and are clickable. (on or off)
When you click one of these, the vars are set to true or false. (images too)
It works, but my page flickers when i click one.
Is there a proper way to do this? I'm not a javascript expert...
index.html
Post Edited By Moderator (Bean (Hitt Consulting)) : 11/3/2009 7:31:45 PM GMT
index.html
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "[url=http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd]http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd[/url]">
<html xmlns="[url=http://www.w3.org/1999/xhtml]http://www.w3.org/1999/xhtml[/url]">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
<style type="text/css">
body {
background-color: #333;
</style>
<script language="javascript">
var xmlRequest;
function SetDefault(id) {
//var varname = document.getElementById("variable_name").value;
if(id=='00'){
var newval =<Nb_var00> != true;
else if(id=='01'){
var newval = <Nb_var01> != true;
else if(id=='02'){
var newval = <Nb_var02> != true;
else if(id=='03'){
var newval = <Nb_var03> != true;
var msg = 'variable_name='+id+'&NewVal=' + newval;
HttpReqPost(msg);
function HttpReqPost(sendtext) {
var URL;
URL = "VALUESET.HTM ";
xmlRequest = getXMLHttpRequest();
xmlRequest.open("post", URL);
//xmlRequest.setRequestHeader("variable", "");
xmlRequest.setRequestHeader("Content-Type", "text/xml");
//xmlRequest.setRequestHeader("Connection", "close");
xmlRequest.onreadystatechange = processReqChange;
xmlRequest.send(sendtext);
function getXMLHttpRequest() {
if (window.XMLHttpRequest) {
return new window.XMLHttpRequest;
}else{
try {
return new ActiveXObject("MSXML2.XMLHTTP.3.0");
catch(ex) {
alert("No http request capability");
return null;
function processReqChange() {
if (xmlRequest.readyState == 4) {
if (xmlRequest.status == 200) {
window.location="index.html";
}else{
alert("There was a problem sending the XML data:\n" +
xmlRequest.status + " " + xmlRequest.statusText);
</script>
</head>
<body>
<img name="in1" src="[url=http://www.tumbler.be/SmartLogicImages/images/Sensor_%3CNb_var00%3E.jpg]http://www.tumbler.be/SmartLogicImages/images/Sensor_<Nb_var00>.jpg[/url]" onclick="return SetDefault('00')" />
<img name="in2" src="[url=http://www.tumbler.be/SmartLogicImages/images/Sensor_%3CNb_var01%3E.jpg]http://www.tumbler.be/SmartLogicImages/images/Sensor_<Nb_var01>.jpg[/url]" onclick="return SetDefault('01')" />
<img name="in3" src="[url=http://www.tumbler.be/SmartLogicImages/images/Sensor_%3CNb_var02%3E.jpg]http://www.tumbler.be/SmartLogicImages/images/Sensor_<Nb_var02>.jpg[/url]" onclick="return SetDefault('02')" />
<img name="in4" src="[url=http://www.tumbler.be/SmartLogicImages/images/Sensor_%3CNb_var03%3E.jpg]http://www.tumbler.be/SmartLogicImages/images/Sensor_<Nb_var03>.jpg[/url]" onclick="return SetDefault('03')" />
</body>
</html>
