Ground and Vcc
I have a chip that I'm currently controlling from the Propeller chip. The input pin on this chip expects to be connected either to ground or Vcc. When it's connected to Vcc the chip behaves in a certain way, and when it's connected to ground it basically turns off that behavior. I'm controlling it with one of the pins, configured for output, on the Propeller. All well and good, it works just the way I want it to because, a 1 written to the Propeller's output pin makes it Vcc and a zero written to the pin makes it connected to ground, right?.
But I now need that chip (let's call it Chip A) to be controlled, not by the Propeller chip, but by yet another chip, which I'll call Chip B. The output pin on Chip B varies between zero volts and Vcc. I want to use that Chip B output pin to control Chip A via its input pin, which expects either Vcc or ground. Will this work? In particular, will a zero voltage value from Chip B be equivalent to ground, as expected by Chip A?
REFERENCED upon the ground of the same CHIP. If you connect all grounds they all have the same reference
best regards
Stefan
