DS1307 on an SX28 PDB (working) vs SX48 protoboard (not working)
I took JonnyMacs DS1307 code and just modified the DEVICE line for an SX48 vs the default SX28. See attached.
I can get the DS1307 code to run fine on my PDB with an SX28 to Hyperterminal 38400. However, if I run the TX, RX, SCL and SCA from the PDB to RA on an SX48 protoboard, sometimes I get strange chars on Hyperterminal and sometimes nothing at all happens. I first thought it was a Baud issue but lowering it down to 19200 and 9600 had no effect.
I also ran a ground wire from the PDB to VSS on the SX48 protoboard. I also used a 4 MHz resonator.
Is there anything else uniquely different between the SX28 and SX48 that I am not seeing here?
Thanks.
Thanks.
ASM MODE $09 ; WKPND_B MOV !RB,#00000000B ; clear pending Port B detections MODE $0A ; WKED_B ; 0 = selects rising edge detection ; 1 = selects falling edge detection MOV !RB,#11111111B ; set high-to-low detection for all Port B pins MODE $0B ; WKEN_B ; 0 = enable pin for interrupt ; 1 = disable pin for interrupt MOV !RB,#11111111B ; MODE $0C ; ST_B/C/D/E ; 0 = enable Schmitt Trigger ; 1 = disable Schmitt Trigger MOV !RB,#11111111B MOV !RC,#00000001B ; enable 1-7 as Schmitt-Trigger MOV !RD,#00000000B ; enable all inputs as Schmitt-Trigger MOV !RE,#00000000B ; enable all inputs as Schmitt-Trigger MODE $0D ; LVL_A/B/C/D/E ; 0 = Sets pin to CMOS ; 1 = Sets pin to TTL MOV !RA,# 1111B ; set 1-3 inputs to TTL levels MOV !RB,#11111111B ; set 1-5,7 inputs to TTL levels, 6 to CMOS MOV !RC,#11111110B ; set 1-7 inputs to TTL levels, 0 to CMOS MOV !RD,#11111111B ; set all inputs to TTL levels MOV !RE,#11111111B ; set all inputs to TTL levels MODE $0E ; PLP_A/B/C/D/E ; 0 = Enable internal pull-up resistor ; 1 = Disable internal pull-up resistor MOV !RA,# 0000B ; do not use internal weak pull-up resistor MOV !RB,#00000000B ; do not use internal weak pull-up resistor on 0-3 and 6-7 ; internal pull-ups for 4 & 5 MOV !RC,#00000000B ; do not use internal weak pull-up resistor MOV !RD,#00000000B ; do not use internal weak pull-up resistor MOV !RE,#00000000B ; do not use internal weak pull-up resistor for 0-6 MODE $0F ; TRIS_A/B/C ; 0 = Sets pin to output mode ; 1 = Sets pin to input (High-Z) mode MOV !RA,# 0000B ; set 0-7 as outputs MOV !RB,#11110111B ; set 0-2 & 4-7 as Hi-Z inputs ; and pin 3 as output MOV !RC,#11111110B ; set 0 as output, 1-7 as Hi-Z inputs MOV !RD,#11111111B ; set 0-7 as Hi-Z inputs MOV !RE,#11111111B ; set 0-7 as Hi-Z inputs MOV !OPTION,#01000000B ; Register $01 is W ; RTCC roll-over interrupt off ; Prescaler assigned to WDT ; Prescaler = 1:1 ENDASM
