Need a hand with the BS2 Stamp + MMA7453 Accelerometer Module — Parallax Forums
bmthomsenbmthomsen Posts: 4
edited 2009-11-03 08:48 in BASIC Stamp
Hi, I apologize in advance for a noobish question....I'm trying to get this sensor to work with the BS2 Stamp kit for a class project, ·and I'm having trouble getting it to do anything. I have it wired up per the instructions in the demo PBASIC program (link below), and the X, Y, and Z values show up in the debug window as -1, and don't change. Checking with a logic probe shows correct voltage levels at Vin and Ground, and signals at the CLK, DATA, and CS pins. This is what the debug window shows:
·· MMA7455 3-Axis Accelerometer BS2 DEMO #1
···················· 8-Bit 2g Mode ; 64 LSB/g
···················· X=-1
···················· Y=-1
···················· Z=-1
I'm not sure what else to check. Anyone have any ideas?
Thx, Brian
(http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/Accelerometer/List/0/SortField/4/ProductID/585/Default.aspx)
    edited 2009-11-02 17:19
    bmthomsen,
    Double check your wiring to the MMA7455 Accelerometer refering to the documentation found here...
    www.parallax.com/Portals/0/Downloads/docs/prod/sens/28526-MMA7455-3axisAccel-v1.1.pdf
    If you run the BS2 program without an Accelerometer connected at all and pull the Data line LOW, then X,Y, and Z will all read "-1".
    Beau Schwabe
    IC Layout Engineer
  • bmthomsenbmthomsen Posts: 4
    edited 2009-11-03 06:01
    I double checked my wiring and found where I was confused...
    The intro to the demo program gives the following instruction:
    ' o Connect P0, P1, AND P2 ON the Stamp directly TO the CS, DATA, AND CLK
    '·· ·pins ON the Digital 3-Axis Accelerometer module.
    The pins are defined as:
    CLKPin··· ·PIN 0···· ' Clock Pin
    DATAPin·· PIN 1···· ' Data Pin
    CSPin····· ·PIN 2···· ' Chip Select Pin
    So I had them wired backwards. I corrected this and am now getting data out of the sensor. Thanks for pointing me in the right direction.
    -Brian
    bmthomsen,
    You bet! Glad you got it working.
    Beau Schwabe
    IC Layout Engineer
