Heat Sensing Keypad
william chan
I recently saw some 3x4 numeric keypad where you actually touch the labeled plastic casing itself.
It seems that there are heat sensors behind the enclosure that can sense your fingertips' touch.
Anybody seen this before?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
can you provide a link? Are you sure it wasn't just a sensitive membrane keypad or capacitive keypad?
Beau Schwabe
IC Layout Engineer
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
Got a reference for that? My data says it's a capacitive screen. Personally I've *never* seen a "heat sensitive" touch screen on any small device.
If you always do what you always did, you always get what you always got.
Yet after doing a little googleing' I found a page that told about all the different types of touch screens on mobile phones (including IR which is what I think meant by the "heat sensitive" comment). It has the pros and cons of the three major types (resistive, capacitive, and IR) and is interesting even if your not referencing phones. Take a look if your interested.
http://www.phonearena.com/htmls/Article-Touchscreen-technologies-in-phones-article-a_3067-p_2.html
Alex Burke
"Beware of computer programmers that carry screwdrivers." -Leonard Brandwein
What is the difference between qt60168 and qt60160?
Which one is easier to use?
www.fd.com.my
www.mercedes.com.my
Amazingly enough, Mouser has them in stock here www.mouser.com/Search/Refine.aspx?Keyword=qt60168
I checked with Farnell and it seems the QT60160 is much cheaper. Why is that?
Can I solder it by hand?
Can I borrow your propeller code for the 60160?
How do you make the printed keypad words/numbers last without fading or peeling off?
www.fd.com.my
www.mercedes.com.my
My 60160 code is written in C for microchip products, so that won't be a good option.
