Nice $10 Gearmotor
I'm starting a new diff-drive robot platform in the 15-pound category.·This will be my biggest autonomous bot yet.·I'm using·two·surplus gearmotors & wheels, and I've tracked·extras down online for ~$10 each at http://www.mpja.com/prodinfo.asp?number=17971+MD·and http://www.allelectronics.com/make-a-store/item/DCM-351/24-VDC-GEAR-MOTOR-W/-TURNTABLE/1.html·. My wheel is slightly different, but the motor·number & specs match, so I'm ordering more.
These are unusually nice·24V gearmotors in a sealed metal case with bushings and spur gears w/minimum backlash. Excellent efficiency, no worm drives here. Motor is a small China-made RS-380SH. Operates nicely at 12V, which is what I plan to use, a big·cheap gel cell.· Stall current is only half an amp at 12V! No-load speed on the wheel provided is a stately ~8 inches/second, ~ 22 RPM. A bargain at $10.
My long range goal is a·large boe-bot/scribbler type BS-2 platform with collision avoidance using encoders and such from·the·Scribbler encoder project.
Post Edited (erco) : 11/10/2009 5:24:19 PM GMT
Whit+
Nov 13 edit: I did find a smaller OD O-ring that fits much tighter, it stays in place perfectly for one-motor turns.
Post Edited (erco) : 11/14/2009 4:12:27 AM GMT
I hope you keep us apprised of your projects progress and I will do the same with mine. I wanted Parrallax's nice motor / encoder but hell, for 20 bucks as opposed to 279.00 I thought I can't go too far wrong. even if it turns out to be one of those all important lessons in what just won't work. All Knowledge is good knowledge. Well god luck my friend and have a lot of FUN.
EverQurious
Try not to fret and worry bout the things that you have not...
Just remember to be thankful for the things you've got !!!
http://www.goldmine-elec-products.com/prodinfo.asp?number=g17222
On Sale for $6.00 each until 12/31/09!
Better late than never! I just snagged 4. Don't know what I'll do with them, but the price was right.
Ron aka sailman58
You indicated on another thread that the precious cargo carriers were up and running. I would love to see some video!
Hope you all had a great Christmas.
Whit+
Great find! That's quite a bargain at $6. I did order 6 more plus some other stuff yesterday. I think you guys will like the motors. Strong & ready to go, great for robotics. Their main quirk is higher voltage (up to 24V), which some small motor controllers can't handle. But the current is low, so you have many options. I'm using my simple 4-state relay H-bridge I posted here a while back with very good results. I have 2 speeds: high is 18V direct, low is 12V direct, plus I have coast and dynamic braking. Ultra-simple. I'll post a video when I can.
Happy 2010,
EverQurious
Post Edited (erco) : 1/9/2010 12:59:39 AM GMT
EverQurious
Post Edited (erco) : 1/14/2010 7:52:34 AM GMT
Moving closer to buying a pair of these motors,
Martin
http://www.goldmine-elec-products.com/prodinfo.asp?number=G17222
I used these in my BS2 Retrobot: http://www.youtube.com/watch?v=PX0IhUqnwrk and http://www.youtube.com/watch?v=VzbKlwc4GWs
Totally off topic - but just can't help myself....
IT'S NOT PLYWOOD! - erco's using real dimension lumber - now that I can support :thumb:
-MattG
https://plus.google.com/photos/117542001281850354871/albums/5750039804734302993/5749715296555693490?banner=pwa
Power is from a single 12V 7Ah battery. It uses a couple Propellers for the brain, SpeakJet and TTS256 for the speech.
Robert
You silly goose. Those are just cross braces. That clearly-visible top plate is 100% bona fide, certified, US-pride, multi-plied, laminied (?), 1/4" plywood.
What do I win for your glaring error? A Quadrover?
Harbor Freight has a coupon book out now with some small pneumatic wheels/tires for ~$3. Time to grab a half dozen. 4 for a rover, 2 for a balance bot.
Do you have a link to those harbor frieght wheels im about to drop 30 at the rc shop for some blow up 5 inch landing wheels but these may be a better fit! the hoolow plastics im using just have no traction and my motors have so much torque sometimes my tires spin out and get caught n small thing while the wheels spin away at 240 rpm
Im curious becuse right now im trying to get my bot to drive, you made an h bridge from relays, then you are using a bs2 to control the pid loop? Where does you pwm signal come from, apparently the bs2 cant generate 2 PWM signals at once from what i found out today
Also I went to harbor frieght http://www.harborfreight.com/catalogsearch/result?q=pneumatic+wheels thats what came up for phneumatic wheels 5.99 is the cheapest. Also all the pneumatic wheels im seeing look heavy like the kind on dollys and such, will these motors drive thos sorts of wheels??!
