Best(?) coding practice in spin? — Parallax Forums
pacmanpacman Posts: 327
edited 2009-11-04 13:06 in Propeller 1
I got to thinking, given the controversy that is being stirred-up in the thread "How would you describe Spin as a language?" is there a 'standard' best practice way you folks use in naming your variables?
I do NOT want to start a flame war here.
Many years ago I got into the habit of using Hungarian notation for naming variables, even with some of the PLC's I'm currently coding with I have adopted a syntax to try and help with future maintenance of code (eg tag_G is an integer, tag_P is a Boolean pulse, _F is a real, _T is a timer, etc, etc).
I realise that in spin adopting these sort of names doesn't _force_ types, but I have found this trick has sometimes help me.
So is there a best/better naming convention I should be investigating? Does it matter? What do you do?
The future is in our hands.
Which way to the future?
    edited 2009-11-01 22:05
    There's no "standard best practice". The names have to be short enough so they're not creating extremely long statements. They have to be meaningful enough to help the reader understand what's going on in the program, particularly after the program hasn't been looked at for a few months. Beyond that it's a matter of personal or corporate taste.
    edited 2009-11-02 00:13
    Hello Pacman,
    I use this kind of variable-naming c_... for constant or p_... for parameterrs sometimes too.
    and I use another two things:
    1) SELF-EXPLAING names
    2) every part of the code that does ONE senseful thing becomes a PUB (in most cases)
    some people call this style of coding "chatty". As I'm the person who has to re-read the code I stay with this style
    In my opinion if you want to maintain code years later with this style it is much easier.
    And with using hotkeys for marking words or lines and copy & paste done by Ctrl-c, ctrl-v the writing of the letters
    is as quick as writing shortnames like sub1, sub2, sub3
    best regards
    Stefan
  • MacGeek117MacGeek117 Posts: 747
    edited 2009-11-02 00:17
    Never underestimate the power of PRI routines!
    Self-explaining names almost always work best, especially when looking at code you haven't worked with for a long time.
    RoboGeek
    BS2: $49
    SX48 Protoboard: $10
    Propeller Protoboard: Priceless
    www.apple.com
    www.parallax.com
    www.goldmine-elec.com
    www.expresspcb.com
    www.jameco.com
    Post Edited (RoboGeek) : 11/7/2009 2:35:51 AM GMT
    edited 2009-11-02 02:18
    If the product of your efforts, including comments, is something you think you can either reuse, or understand some years later, then you have done well. Bonus points are scored, if others will find it the same.
    Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
    Safety Tip: Life is as good as YOU think it is!
  • HughHugh Posts: 362
    edited 2009-11-02 13:20
    I tend to give variables names in camel-case, e.g., "intNumberItems", "boolDataFlag", even if these types are all type byte.
    Recently I have started to call PUBs names such as 'callSendData' so that when I see that in the calling PUB it makes more sense (to me at least!)
    Hugh - the thinking woman's Geoffrey Pyke.
  • Nick MuellerNick Mueller Posts: 815
    edited 2009-11-02 13:52
    Even if SPIN isn't type aware, using some method to show what the variable is meant to be made of is good practice.
    I use(d) pXXX fpr pointers, iXXX for ints, bXXX for bools .... eXXX for enums etc. Functions start with a capital. Also the "camel-case" (LOL!) method.
    Whatever practice you use, as long as you use it consistently is OK.
    There are no "rules" that I'm aware of.
    Nick
    Never use force, just go for a bigger hammer!
    The DIY Digital-Readout for mills, lathes etc.:
    YADRO
  • pacmanpacman Posts: 327
    edited 2009-11-04 02:01
    So perhaps _we_ (the community) should come up with some _suggested_ guidelines for inclusion into a sticky thread or the next propeller book.
    If we got some form of consistency going then wouldn't that be another step towards making the propeller "even more better"? Imagine being able to pick up the next object and instinctively know when Bob is incrementing an integer or pointer..
    Obviously, not everyone would conform (and that would be perfectly OK), but those that did might find it helps the next person who comes wandering in...
  • BradCBradC Posts: 2,601
    edited 2009-11-04 02:23
    pacman said...
    Never gonna happen. Everyone comes from a different background and brings a little of that with them. To try and put a set of guidelines together is like trying to ask everyone to change the way they do what they do. Diversity is good. Unfamiliarity is good. It makes the reader try just that little bit harder to understand what is going on and by having to study the code a little closer they might gain a better understanding of what is really happening.
    It's a bit like when I issue a tender. I never, ever accompany it with a bill of quantity. By making the tenderer actually read the drawings to count the quantities, I have a better chance of ensuring they actually understand the project rather than just filling out a spreadsheet.
    I know it sounds like work, but as Calvin's dad would say "It builds character". Or in this case, it helps build skill. Like any skill, it gets easier the more you do it.
    If you always do what you always did, you always get what you always got.
  • jazzedjazzed Posts: 11,803
    edited 2009-11-04 02:24
    potatohead said...
    That is the key.
    Microsoft once used variable names like szName, but that practice is not promoted much now.
    Adding special characters for types is interesting, but that is not really important to everyone.
    I prefer camel-case only because under-bars take up space (SPIN identifier size is limited to 32).
    Usually the context of an identifier is enough. I capitalize constants out of habit for any language.
    I use g<Name> for globals in C for clarity of scope. Spin scope is naturally clear to me.
    Added: Well stated BradC.
    edited 2009-11-04 11:17
    And adding to Brad:
    No, if someone has his style, he won't change it. The good thing is, that any style is obvious (hopefully, more or less) so it should be easily understood after reading some 10 lines of code.
    Anyhow, I'm breaking my rules frequently like for the often (ab-)used "i" for a counter in a *narrow* scope (just a few lines). Or "j", if the "i" isn't enough, or "ndx" as an index into an array.
    Didn't Don Saks (?) write a book "C/C++ guidelines" or such that has helpful suggestions about that suject?
    Nick
    YADRO
    edited 2009-11-04 12:06
    For narrow-scope integers I tend to use i, j, k & l as a carry-over from Fortran! I am the one needing re-programming - not the Prop.
  • agodwinagodwin Posts: 72
    edited 2009-11-04 12:44
    Nick Mueller said...
    Nick
    I think perhaps BECAUSE spin isn't type-aware, this might be a good thing.
    I've always hated 'hungarian' notoation, feeling that it's the compiler's job to look after types, not mine. I accept that it might be occasionally useful to distinguish object sizes to avoid accidental truncation, but unnecessary for distinguishing pointers etc. .. the C compiler will tell you about that.
    But one of the errors I frequently make in spin is failing to sign-extend when assigning or calculating using a word or byte operand. A reminder in the variable name might help.
    Perhaps more important is access : I tend to communicate between cogs using shared variables and a reminder that I need to think about atomic operations (either with careful usage or a specific semaphore) could help avoid some more bugs.
    edited 2009-11-04 12:55
    I use the tags even in type aware-languages to see type-propagation problems. Some compilers aren't picky enough about that.
    Nick
    YADRO
  • Ken PetersonKen Peterson Posts: 806
    The important thing is to pick a style that works for you and be consistent with it. If you find a particular style to be more cumbersome than useful, don't use it. Always try to write code as if someone else is going to have to read it, even if you think no one else will. You might as well be someone else if you're trying to read your own code a few months down the road.
