Play wavs backwards?
I am trying to play wav files using the propeller in a way that allows me to use a velocity to determine progression in a song. So far I have forward (positive) velocity working, but I am really at a loss to how I can get backward (negative) velocity working. How could a wav file be played backwards off of an SD card?
Not the fish.
sites.google.com/site/bitwinproject/
Not the fish.
Pretty much impossible with the prop due to the amount of overhead that would add.
...But then it could be possible. If your code is fast enough.
Nyamekye,
So, I think you have 2 basic options:
1 - use an older version of FSRW with a single-block driver
--- lets you go backward with as little overhead as possible
--- you will still need to reverse the samples in each 512-byte block
--- will most likely still _not_ work on SDHC (any SD card > 2GB), all the ones I tested are very slow in single-block mode
2 - Use some software on the PC to reverse and save a backwards copy of the file (Audacity can do it, and is free)
--- use the newest version of FSRW (2.4) to open both files at once
--- if the sign of the direction changes, switch the the other file, and use the seek function to jump to your start point
Jonathan
lonesock
Piranha are people too.
