SX Robot
Hello,
I want to make some robots similar to the BOEBot (homemade for some local schools). I hate to waste these chips and components. Plus the kids always like my science demos. I am a professor of Archaeology at a university in Louisiana. I am learning electronics for my hobby. I have used the SXB before and I was thinking I could use a 555 timer for send IR and using continuous sevos from Parallax (I have 10) to drive the robot wheels and the chips to detect IR. Is there a sample of such a robot anywhere?
Curtis
Curtis
One example of complete 'bot on an SX is here: http://forums.parallax.com/showthread.php?p=814301 although this 'bot uses PWM for motor control instead of servo pulses (in honesty, using servos is simpler and requires much less of a hit ISR-wise).
I downloaded the pdf, schematic, and code (zip). The code (zip) is not valid. Thanks for you help,
Curtis
