Scoreboard
Chris Steiner
I am relatively new to this forum. I am looking for a stamp project for a homemade scoreboard (backyard icerink). Anyone come across a basic stamp project of this nature?
My scoreboard needs to countdown from twenty minutes. I have done two seven segment display countdowns before, but never 4. I am not sure how to multiplex with 4. As far as size is concerned, as big as possible. I do like the 6" displays mentioned above, but I may drive something even bigger with relays. Right now I just want to focus on the code. Do you have any suggestions?
Now something else I tried is once is putting a magnifying
Glass in front of the digits, and sending them to a light colored wall, you can get 6 foot
Numbers this way, but hard to see in a lighted room.
The bs2 file that you link to above explains a lot. I guess I was just looking for the same thing counting down from twenty minutes using 4 seven segment displays.
Larry, I like the magnification idea. I just don't have a large barn to illuminate upon next to our ice rink.
I used the electro-magnetic-mechanical "flip" type displays from the Staver company in NY. I see they have been bought out by Signalex Corp. These displays were easy to interface to and required very little power since they only needed a pulse to flip one way or the other. A magnet then held the element in place. Ran on several D or C size batteries. I forget which.
I used a PIC chip back then to run the scoreboard. This could easily be done with a basic stamp and even incorporate some wireless magic to eliminate the control tether cable.
I'll post some pictures later. I'll have to dig the unit out of the garage. Its been a while since it has been used.
