datalogger and protoboard — Parallax Forums
coppercladcopperclad Posts: 4
edited 2009-10-30 17:26 in Propeller 1
Hi
i have a proto board hooked up with the parallax keyboard and a NTSC display
·i would like to hook up the datalogger and i am wondering if anyone can point me in the right direction
·where can i find spincode to access the datalogger for the propellor chip and my configuration of keyboard and display , any help would be great , thank you
    edited 2009-10-30 16:57
    Look in the Propeller Object Exchange. There's an object specifically to interface with the datalogger (Memory Stick Datalogger).
    The fact that you're using a PS/2 keyboard and NTSC display shouldn't affect the use of the datalogger object.
  • coppercladcopperclad Posts: 4
    edited 2009-10-30 17:12
    Hi Mike
    thanks , i was just using search to browse completed projects , and came across the memory stick datalogger , i will give it a try
    i had seen that , they do have some sample code listed on the datalogger page http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/434/Default.aspx?txtSearch=data+logger, but it uses an LCD display and i can't tell if it is written for the prop or BS2 , also there is no schematic , so i was slow to jump into it
    thanks again
  • SRLMSRLM Posts: 5,045
    edited 2009-10-30 17:14
    What is the goal of your setup? I submitted an object yesterday that automatically logs:
    obex.parallax.com/objects/534/
    Otherwise, you can use one of the other datalogger programs.
    edited 2009-10-30 17:23
    HI Mike
    i guess this was the post i saw in my search and it does not seem to be relevent to the prop
    http://forums.parallax.com/showthread.php?p=780369
    i guess what i am trying to find out , is there a section for prop based spin code , the completed projects section ???
    i hear you guys saying "you can use one of the other datalogger programs" but i am new on the forum and don't have a clue where to look , thanks again
    Hi
    how do i get to the object exchange???? , thanks
    thanks i figured out where it is
    http://obex.parallax.com/objects/
    thanks again
    Post Edited (copperclad) : 10/30/2009 5:31:46 PM GMT
