"Psycho Pumpkin" for Company Pumpkin Carving Contest — Parallax Forums
aalegadoaalegado Posts: 66
edited 2010-03-04 19:00 in Robotics
My company held a pumpkin carving contest and my department entry won first place with the help of a Basic Stamp driven light and sound show. It's not anywhere near the quality of a commercial halloween haunt but it was still pretty entertaining. None of the other entries had any light or sound effects so I might have won because I brought an assault rifle to a knife fight! :[noparse]:)[/noparse]
I used a Parallax Board of Education connected to a second breadboard to hold all of the LED driver circuits: One ULN2803 (I used only one channel to control the relay) and 6 discrete 2N2222-based drivers for the "high current" LEDs. I used discrete transistors as a defensive measure: Many of the LEDs are lit at the same time (or close enough time-wise) and I didn't want to overheat/damage the ULN2803.
The entry consisted on a carved pumpkin mounted on a wood stand with several different LED lighting effects and a "psycho" music sound effect at the end of the sequence. The stand was hidden in a pair of baby's jeans and the electronics in a handy card board box I put behind the stand. The effects (in order that they occur):
  • White LED illuminates the Bate's House. Stays lit throughout rest of sequence.
  • The pumpkin's yellow LED eyes flicker. They "randomly" flicker throughout the rest of the sequence.
  • Blue LED "neon" sign flickers and then turns "on." The neon sign "randomly" flickers throughout the rest of the sequence.
  • "Psycho Pumpkin" sign lights up. The sign "randomly" flickers throughout the rest of the sequence.
  • White LED lights up behind a image of the bloody hand touching the shower curtain from the shower scene in the movie "Psycho." At the same time, red LEDs located behind the shower curtain flash ("blood" spatter), a sound effect is played (the piercing theme from the shower scene in the movie "Psycho"), and the servo-controlled, knife-wielding arm moves in and out towards the shower curtain
  • After a few knife strokes, everything stops/goes dark and the sequence restarts after a four second delay.
The sound is provided by a greeting card with a 10 second record/play-back capability I found at Target for $7. It required a normally-closed switch to open in order to trigger playback so I used a SPDT relay wired in parallel with the greeting card's switch mechanism.
Here's a link to a Facebook photo album: www.facebook.com/album.php?aid=2042972&id=1293091406&saved
Here's a link to the YouTube video of it in action: www.youtube.com/watch?v=xUAO4VKsa48&feature=player_embedded
I wouldn't connect that if I were you...
Vive Le Tour!
Le Grand Depart July 6-8, 2007
  • Shawn LoweShawn Lowe Posts: 635
    edited 2009-10-29 17:29
    aalegado-
    Cool prop! Good job, can you post your code?
    Shawn Lowe
    When all else fails.....procrastinate!
  • aalegadoaalegado Posts: 66
    edited 2009-10-29 17:34
    I don't have the code handy right now...I'll post it tonight.
    edited 2009-10-29 21:25
    You should definitely post some pictures (and code) as per the guidelines for posting in this forum. Members who don't have a Facebook account cannot see your linked photos.
    Parallax Engineering
    edited 2009-10-30 04:08
    Attached are the program listing, circuit schematic, and some photos of the pumpkin.
    The code is relatively unsophisticated: There is a main loop that uses a combination of HIGH/LOW statements or subroutine calls to light different combinations of LED effects.
    Certain effects are actually pre-defined sequences of HIGH/LOW of a particular LED effect such as the simulated Neon sign (it flickers slowly, then quickly, and then stays "On" like a Neon sign might do). I created these sequences by experimentally determining combinations of the HIGH/LOW statements with different PAUSE values. There Neon sign subroutine itself calls subroutines to flicker the Eyes, flash the Sign, etc. By re-using subroutines and/or nesting shorter LED effect subroutines in the larger Neon effect subroutine, I was able to build a complex-looking lighting sequence.
    After going through different combinations of subroutine calls, the FOR-NEXT loop is used to operate the servo and cause it to move back and forth about 0.125" which is enough to operate the "knife-wielding arm" effect. Lighting effect subroutines are called from within the loop to cause all the LED effects to flash in synch with the knife strokes. After a few strokes, everything goes dark and the sequence starts over.
    My crude, hand drawn schematics need some explanation:
    Circuit "A" is the typical circuit used to drive either a motorcycle LED lamp strip or a three RGB LED array. These LED lamps/arrays were chosen because they were easy to build into the pumpkin display and had built-in current limiting resistors. Three iterations of circuit "A" were made to support the simulated Neon light (using just the Blue segments of the RGB LEDs), the "Psycho Pumpkin" Sign (two, 12V motorcycle LED lamp strips in parallel), and the Shower Scene red LED flicker effect (using the Red segments of the RGB LEDs. V+ is the Vin provided by the unregulated, 12V wall-wart that comes with the BoE.
    Circuit "B" is the typical circuit used to drive discrete LEDs. It's basically the same circuit as "A" except I had to use a discrete current-limiting resistor. Three iterations of circuit "B" were made to support the House and Shower LEDs (both were very high intensity 1W Luxeon white LEDs; these used a 100Ohm 1/2W current-limiting resistor), and the paired yellow LEDs that made up the Eyes (these LEDs used a 470Ohm current-limiting resistor). V+ is the Vin provided by the unregulated, 12V wall-wart that comes with the BoE.
    Circuit "C" is the relay used to trigger the greeting card sound module. The relay's NC contacts were wired in parallel with the trigger for the sound module's customer-recording sound (this was the shower scene theme music from Psycho). The sound module stored 10 seconds of low quality sound—a bit harsh on the ears but very recognizable. The relay is driven by one channel of a ULN2803 driver IC. V+ here is actually Vdd from the BoE.
    Finally, circuit "D" is the hook-up for a Futaba servo.
    Circuits A and B were built on a small breadboard. Circuits C and D were built onto the BoE's small breadboard. The BoE and small, separate breadboard were put into a small cardboard box positioned just behind the legs of the pumpkin.
  • WhitWhit Posts: 4,194
    edited 2009-10-30 14:19
    aalegado,
    Great project, pics and video! Based on most of the carving contest I've seen, you did bring an assault rifle to a knife fight!
    Whit+
  • logan996logan996 Posts: 281
    edited 2010-03-02 20:24
    chris,
    this is probably a bit late but actulley someone who does not have a facebook acct. can actulley veiw someone's picture album on facebook if given a link
    Chris Savage (Parallax) said...
    "When the government is afraid of the people there is liberty, when the people are afraid of the government, there is tryanny"
    ·Thomas Jefferson
    edited 2010-03-02 20:38
    logan996 said...
    if given a link
    Facebook, Youtube and America blogs are blocked in China.
    So no matter what Facebook, or Youtube link you give, it will not show up.
    It is important to post project information on the Parallax Forum server and
    not just link it to an outside site.
    humanoido
    Providing the details here is a good idea for many reasons. Besides those already mentioned, what if the photos are removed from the target site for some reason? You links become broken. We backup our systems here so when projects are posted in entirety, we know the data will always be there for the customer.
