Long directory listing using fsrw
pgbpsu
I'm trying to use fsrw to read the contents of an SD card and return both file names and sizes. However what I thought would work doesn't. Here's what I'm doing.
Here's what I get:
Listing Directory Contents:
140709.CSV filesize:32768
160709.CSV filesize:32768
09091900.22M filesize:32768
That's what you've got on disk!
The file listing is correct but the sizes are not. It seems to get the correct file sizes if I open each file using popen and then request the size:
09091900.22M filesize:1600752
This works.
So my question is how can I loop over each file on disk without creating an array in which I store ALL the file names. I don't know how many files will be on the disk but it should reach into the hundreds. I don't want to set aside that much memory in the Prop for something that's already saved on the SD card.
It seems like this should be straight forward, but I'm clearly missing something. Thanks in advance for any suggestions.
Peter
uarts.str(DEBUG,string(13,"Listing Directory Contents: ", 13))
sdfat.opendir
repeat while 0 == sdfat.nextfile(@tbuf)
uarts.str(DEBUG,@tbuf)
uarts.str(DEBUG,string(" filesize:"))
uarts.dec(DEBUG,sdfat.getfilesize)
uarts.str(DEBUG,string(13))
uarts.str(DEBUG,string(13,"That's what you've got on disk!", 13))
Here's what I get:
file_open := sdfat.popen(@tbuf, "r",2008,12,9,12,10,10)
This works.
Peter
OBJ sdfat[noparse][[/noparse] 2 ]: "fsrw" ' make sure to mount sdfat[noparse][[/noparse]0] (you only need to mount one of the array) PUB show_dir ' opening the dir is just like opening a file sdfat.opendir repeat while 0 == sdfat.nextfile(@tbuf) ' show the filename term.str( @tbuf ) repeat 15 - strsize( @tbuf ) term.tx( " " ) ' so I need a second file to open and query filesize sdfat[noparse][[/noparse] 1 ].popen( @tbuf, "r" ) term.dec( sdfat.get_filesize ) sdfat[noparse][[/noparse] 1 ].pclose term.str( string( " bytes", $0D ) )Jonathan
edit: forgot the spaces inside the [noparse][[/noparse] ] brackets
lonesock
Piranha are people too.
Post Edited (lonesock) : 10/29/2009 3:56:35 PM GMT
Thanks for the reply (and all your work on the code). I'm using FSRW 1.7. I tried 2.3 but ran into problems with my cards so I backed up to what I already had working. I'll have another crack at 2.3 to see if that will solve it.
Peter
Post Edited (pgbpsu) : 10/29/2009 5:20:02 PM GMT
uarts.str(DEBUG,string(13,"Listing Directory Contents...", 13)) uarts.str(DEBUG,string( "FILENAME SIZE(BYTES)")) num_files := 0 sdfat.opendir repeat while 0 == sdfat.nextfile(@tbuf) num_files++ uarts.putc(DEBUG,13) repeat j from 1 to num_files bytefill(@tbuf, 0, 20) ' zero out tbuf sdfat.opendir repeat j sdfat.nextfile(@tbuf) file_open := sdfat.popen(@tbuf, "r",2008,12,9,12,10,10) uarts.str(DEBUG,@tbuf) repeat 15 - strsize(@tbuf) uarts.putc(DEBUG,32) uarts.str(DEBUG,Num.ToStr(sdfat.getfilesize, Num#SDEC11)) sdfat.pclose uarts.str(DEBUG,string(13)) uarts.str(DEBUG,string("Total number of files: ")) uarts.dec(DEBUG,num_files) uarts.putc(DEBUG,13)Here's what it produces:
140709.CSV 324308
160709.CSV 9144
09091900.22M 67584
_~1.TRA 4096
09091906.08M 116736
09091915.00M 589824
09092000.03M 829440
09092100.03M 632832
SPEED.TST 64512
SPEED2.TST 64512
09102121.25S 8003760
200929~1.SU 1600752
200929~2.SU 1600752
200929~3.SU 1600752
200929~4.SU 1600752
200929~5.SU 1600752
Total number of files: 16
Which is correct; so I guess this is solved except that now I'd like to know how much of the disk is used and how much is free. Any suggestions on that?
Peter
Jonathan
lonesock
http://forums.parallax.com/showthread.php?p=844245
Jonathan
lonesock
Jonathan
lonesock
By the time I checked my mail and read your post, I've found a workable solution. Thanks for the suggestion, I'll have a look at PropCMD.
@lonesock-
A method to read the actual card size would be great (as long as it's not too much trouble). Since I'm reading each file's size I can keep track of the total and subtract it from the card's actual size. If that's within +/- 10% of the free space on the disk that would be fine. That would meet me needs.
Peter
(BTW, if you pull the latest version of FSRW off the Mercurial server at SourceForge, there is a setdate function, which might be of use to you: fsrw.hg.sourceforge.net/hgweb/fsrw/fsrw/ )
Jonathan
lonesock
More problematic is the Spin code to check which entries are free; a typical FAT has 65K entries, each of which must be
individually checked. This would take perhaps a second or two in Spin (unless someone can come up with a super-fast
way to do it in Spin without executing an op for each entry).
If a slow one is sufficient, say the word and I'll write it.
File size during directory listings: that can be done.
Note that FAT32 includes an entry in the boot block that is the free space on the card (I think). fsrw does not currently
update this value (doing so would/could slow things down, and also increases the chances of trashing the card). It also
does not use this value. If the prop were a larger system with more memory, we would almost certainly maintain this
value and use it (and thus avoid the FAT scan).
FSRW *could* be modified to track the count of free FAT entries itself, so the free space scan could be done *once* and
then every subsequent time that value would just be updated based on fsrw's work. This way only the first free space
call would be slow and every subsequent one would be fast. This would be a tiny bit more work (mostly in the testing).
If this suffices where the slow-every-time does not, let me know.
Returning the "size of the card" is trivial (if you mean the size of the formatted volume on the card); returning the raw
size is a bit more work (but I've done it before) but is also probably less useful.
When I first searched the forums for help with filesize stuff I found a list of features Kye was working on. But I'm unable to locate that code and haven't heard anything from Kye (but it's not even been a full day yet and I have no idea what time zone he works in). The setdate function may be of use. This application has gps time and I'm actually using to to successfully time stamp my files. I have yet to find out if the fixed time/date I'm using in my popen when reading files sizes changes anything. I hope not; that's why i used the "r" option. I totally understand about being busy so please don't worry about this.
@rokicki-
I think we may have have gone round about this once before but at the block layer. After looking around a bit, I found some old code of mine that keeps reading the blocks until it craps out and claims that's the size of the disk. I'm not sure that was ever such a good idea and other than writing it up and playing with it, I never used it. I've moved up a layer to spin and my timing requirements are pretty relaxed. A routine that took a couple of seconds wouldn't be an issue for what I'm currently doing. I should point out that my working platform uses fsrw 1.7 and I'm only using disks formatted as FAT16.
Peter
Jonathan
lonesock
Thanks for pointing out rokicki's comment about 'size of card'. I somehow missed that.
Indeed, I just want to know what size the formatted volume card. Is it as simple as clustersize * clustercount?
Even I can do that!
p
disk_KB := (sdfat.getclustersize >> 10) * sdfat.getclustercount
Jonathan
lonesock
you'll get kilobytes. That will suffice for a card size well past what SD cards are spec'ed to support.
Peter
count, so you'd have to do the multiplication/scaling yourself anyway.
