Best method to Measure Pulse Width in PASM
I'm working in PASM and I am learning as much as I can on my own with some help from various users on here.
I have finally been able to write a program that sends data to a 74hc595 shift register..it was a great day for me.. [noparse]:)[/noparse]
Now I want to read data from a Maxbotix Sonar sensor... using the pulse width method.. I'm just wondering if someone can point me in the right direction.
I was playing with WaitPEQ and WaitPNE command and measuring the time difference... Is it that simple? Any Guidance would be appreciated.
Eric
PS oh yeah.. What about dividing CNT by 1000 ? Division in PASM is well beyond me at this point in time.
Eric
Use counter A to count in case pin is low
Use counter B to count in case pin is high
From time to time (the time should be close to the frequency of the PWM signal) you read the counters and set them to zero again.
The ratio of the read counter values is equal to the pulse/pause ratio.
Of course you can do other things while the counters count or you wait with a waitcnt ...
start_again waitpne mask, mask ' wait for low mov start, cnt ' start timer waitpeq mask, mask ' wait for high mov pulse, cnt ' end timer sub pulse, start ' get duration sub pulse, #5 ' some type of compensation will be needed, 5 or 9 cycles is likely wrlong pulse, pulseaddr ' output the value to an address jmp #start_again ' continue to measure?As for dividing cnt by 1000, the easiest way is to have the SPIN portion of your code do the dividing (before or after the PASM is called, depending on your requirements).
If you want to do it in PASM, I haven't used this in a while, but I don't see why I would have broke the code any time recently. Put numerator in par1, denominator in par2, and the result will be stored in ret_val. The inputs are limited to 16 bits. I know there is better dividing code out there
'----- DIVIDE ---------------------------------- ' par1 / par2 divide SHL par2, #15 ' get divisor into y[noparse][[/noparse]30..15] MOV midx, #16 ' ready for 16 quotient bits :loop CMPSUB par1, par2 WC ' if y =< x then subtract it, set C RCL par1, #1 ' rotate c into quotient, shift dividend DJNZ midx, #:loop ' loop until done MOV ret_val, par1 ' move to return divide_ret RETSpin uses this code (32-bit compatible), but it is a bit more of mess:
mdiv shr y,#1 wc,wz 'divide rcr t1,#1 if_nz djnz t2,#mdiv mdiv2 cmpsub x,t1 wc rcl y,#1 shr t1,#1 djnz t2,#mdiv2 test a,#%01000 wc negc x,x test a,#%00100 wc test a,#%00001 wz if_z negc x,y jmp #push▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X08/4 ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't make strings the bane of the Propeller, bend them to your will!
Post Edited (Bobb Fwed) : 10/28/2009 3:48:19 PM GMT
Some of my objects:
Lawson
Lunch cures all problems! have you had lunch?
Yes, that is by far the easiest, fastest method. But then you are forced into binary division. But seeing as you now using a type of "binary" division, it limits your output. I would guess you would want the dividing by 1000 to return your results as some multiple of a second (milliseconds, microseconds, etc.).
It all really depends on your application of the dividing by 1000. Can't wait until the Prop II, it is supposed to have some type of value dividing circuitry (not single-cycle instruction). Sounds interesting, but would be very nice to have.
Some of my objects:
round TJZ shpos, #:skip ' skip this if being shifted by 0 SUB shpos, #1 SHR val, shpos ' "divide" SHR val, #1 WC ' put "half" bit in c ADDX val, #0 ' if "half" bit is set, round up :skipshpos is bits to shift (in this case 10 is probably what you'll want to set it to)
EDIT: fixed typo
Some of my objects:
Post Edited (Bobb Fwed) : 10/28/2009 8:25:51 PM GMT
I decided to follow Jeff Martin's ASM web seminar example and have the ASM code measure the High Time of a pulse from a function generator attached to pin 10.
I am using the Pro Deveopment Board.
The high time measurement using a cog's counter A ended up being the same as that of the BS2 Functions code.
Looking at that was a good learning exercise, my original stab at it did not wait for the signal to be low before clearing the counter. That did not work.
I was giving the counter function more credit for watching for that than I should have.
The best examples of using the counters is in PELabsFunBook-v1.1.pdf.
Next version will be to add a Command = 2 to use counter B to measure the low time. Just for leaning.
I also attached a spin only using the BS2 Functions, at the time I typed this in my code was doing nothing and this told me
the counter can do it I just did not have it figured out.
Using the counter is a clean way to do it with microsecond displayed results.
Tom
