Need help to build my balancing robot
I want to build a balancing robot using this part :
1. Propstick USB from Parallax
2. 5DOF IMU from Sparkfun
3. Motor Mount and Wheel Kit with Position Controller from parallax
4. HB25 from parallax
i have no idea to build the programming the balancing robot, would you like to show me some direction to build this robot,,, thank you b4
You might want to ask a more detailed question.
The Propeller Object Exchange is one source of examples and building blocks.
The Google search engine (search.parallax.com) can be helpful. For example, here's a thread on Kalman filters and their use for a balancing robot that showed up on a search for Kalman and Propeller: http://forums.parallax.com/showthread.php?p=696561.
