Pull up resistor on P28
I'm doing some design work, and have a question.
Will a pull up resistor on P28 cause a problem with the Propeller boot operation?
I figure not, but I want to make sure before the prototypes are made.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
James L
James L
Partner/Designer
Blade2 has them too.
Style and grace : Nil point
Thanks Toby. I figured that was the case. As I understand it, a pull up is not needed for boot, because the Propeller drives that line actively, but if a pull up is present, it doesn't matter.
James L
James L
Partner/Designer
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
I too would like to see an equivalent circuit for the propeller i/o pins, or more specifications at least. I would also like to see a recommended timing diagram for the programming sequence.
Rgds, David
Nice to know it's not just me, and at least two of us can't find the data -- yet need it.
Jack
