Tcs230-db
I have started to work with a TCS230-DB and a Basic Stamp HomeWork ( Using a·DB Expander)·and I have troubles·with the·Sensor's LEDs. They do not turn on. I·have·downloaded·a program, to· extract color data from the TCS230-DB via the DB-Expander,··from paralax.com, and it seems to work but the LEDs do not ligt. I suppose that I have not wired the circuit correctly. Can anyone help me? Thanks
It works! but they are blinking, does it have to do with the voltage. The batery is 9 volts. Do I have to use a resistor?
Thank you!
·Rosana
Regarding the voltage, the 9V battery is regulated on the Homework board to 5V. I assume (hope) you're feeding +5V (i.e. Vdd) to the sensor board, as I instructed above, not Vin. Correct?
Rosana
