touch sensor
Looking for your advice.
I have a need for a touch sensitive pad for paragliding accuracy competitions. Generally it is a pad at least 30cm in a diameter and we should be able to measure distance from center within accuracy of 1 cm. Pad should be resistant to impacts, all possible weather (moisture, cold, heat, and so on).
We should be able to fix the first touchdown and ignore everything after.
Pressure could be anything from 0,5 kg to more than 100kg.
Your ideas of making this?
Best regards,
Andrievs
P.S. after we could get a signal everything is simple - no problems with electronics & programming
Best regards,
Andrievs
