2125 datasheet drone said... TOUT – This pin is the buffered output of the temperature
sensor. The analog voltage at TOUT is an indication of the
die temperature. This voltage is useful as a differential
measurement of temperature from ambient and not as an
absolute measurement of temperature.
You'll need an ADC or RCTIME circuit to read it, and as you can see, it might not be what you're hoping it would be anyway.
Tout is a voltage. RCTIME is used to measure a voltage. What don't you understand? Hook up Tout where you would hook the voltage to be measured by RCTIME and run the program....
If you have not already, look at Tracy Allan's website www.emesystems.com under the "app-notes" link. You'll see a discussion on using RCTIME including how to use it to measure voltages. He includes drawings and component values. Treat Tout just like Tracy treats a battery voltage.
Yes, it's a good idea but needs stable components (681 kohm +- 1%) and can't work with voltage under threshold voltage of the BASIC Stamp chip. Memsic 2125 has an output calibrated to 1.25 volts at 25.0° C and the output change is 5 mV / °C. I'll try with an external analog to digital converter. Thank you for your help.
P.S.: I think that Activity #1, Chapter 6, page 182 "Testing the LM34" of Process Control can be used for Memsic 2125. What do you think Mike?
- Stephen
- Stephen
Post Edited (MichelB) : 10/29/2009 5:27:02 PM GMT
