Multi-bank editor Problem
Hi all Starting to try multibank programming,created 3 files & when do syntax check get this error
EXPECTED "}",CAN NOT SPECIFY PROJECT FILES OUTSIDE OF PROJECT PROGRAM0· ( upper case for exact error box dialogue ).
files attached ,they are blank except for header lines.
if you close any of the three they all close & open in same way ???
anyone know what i am doing wrong.
Regards Adrian
Regards Adrian
Tom Sisk
http://www.siskconsult.com
Currently you have the following on your main program:
' {$STAMP BS2p,PaddlesV2Slot0.bsp,PaddlesV2Slot1.bsp,PaddlesV2Slot2.bsp}
' {$PBASIC 2.5}
Try changing it to this.
' {$STAMP BS2p,PaddlesV2Slot1.bsp,PaddlesV2Slot2.bsp}
' {$PBASIC 2.5}
You will have the slot 0 program as a standard BASIC Stamp directive, and the other slots as the file name. Here is a article that should also help with programming across multiple slots.
Also, in the other 2 programs you can use the standard BASIC Stamp directives.
' {$STAMP BS2p}
' {$PBASIC 2.5}
Multi-slot Programming:
Nuts & Volts Volume: 3 [noparse][[/noparse] article 87 ]
http://www.parallax.com/Resources/NutsVoltsColumns/NutsVoltsVolume3/tabid/445/Default.aspx
I hope this helps,
Respectfully,
Joshua Donelson
www.parallax.com
