gps & memory stick logger
hi,
I'm working with the gps module to make it work with a memory stick datalogger to do datalogging. anyone knows of any source code or example code ?
http://forums.parallax.com/showthread.php?p=835322
You really need to go to the Parallax website more often. You'll see all sorts of cool projects like that one.
I have tried the link you mentioned thanks very much. However, I encounter some problems.
It is stucked at the waiting for GPS signal line for a very long time.
I did it in an open space so it should not be a problem in detecting signal from the satellite.
Hope anyone can help me with this problem.
Thank you
Post Edited (nico) : 11/4/2009 6:30:36 AM GMT
To verify the connections, can you post a picture of your set up?
Respectfully,
Joshua Donelson
www.parallax.com
