Finding inexpensive hardware
Does anyone have any suggestions on where to find hardware for bots (mounting brackets, scrap metal for the body, etc...).· I have completed the boebot and would like to move on to some projects of my own, but am struggling with getting hardware.· I was thinking of purchasing some erector·sets for 'mocking' up a rig before committing to purchasing something more permanent.
I was not able to locate anything in the forums along these lines, so I am opening this thread up.
Thanks.
Thanks.
Depending on where you live, junk yards can also be a bonanza.
John R.
Click here to see my Nomad Build Log
Post Edited (Prettybird) : 10/28/2009 2:47:33 AM GMT
I tore a couple of old ones apart, cut the tray open/close drive out with gearbox/belts still attached, glued a piece of plastic tubing onto the final drive gear hub and made a wheeled robot. I used the cd body stamping as the body of the robot. The body is just slightly larger than a boebot, I think.
The slide for the laser head position is usually a guide rail slide driven by a rack and pinion gear. The motor is a simple straight DC motor. I still cannot understand why they don't use a stepper motor for this, and how they control the laser head position with no feedback. Anyways this slide makes a great little catapult. Just attach a pivot arm with an extension spring, use the slide to pull back the arm and rig a release trip at the back position. It shoots a ping pong ball a couple of feet at least.
I did make one minor mistake when I first built my drive using the·CD players.·The CD players are designed to run off the 12 volt power of the pc. Pc's have 12 volt and 5 volt systems (and sometimes something around 3 volts for the processor). I wasn't getting alot of power out of mine until a coworker mentioned that they might need the 12 volts. An upgrade to my battery pack made a lot of difference!
I havn't opened one yet but I bet there are some nice drives, and maybe some soleniods in a vcr tape eject system. You might be able to use the tape up/down in/out·motion to build a nice walker. It might be better to try to get matched set componets as I did have to vary the PWM of my two drives to get them matched to the same speed.
humanoido
humanoido
Post Edited (humanoido) : 11/3/2009 11:03:02 PM GMT
