looking for propeller objects
Hello
i have been looking in the propeller objects section and can not find a few objects i need
Parallax 433 MHz RF Receiver
Parallax 433 MHz RF Transmiter
Parallax 4x20 Serial LCD (Backlit)
am i looking in the wrong place or do i have to use an existing object and make that work?
all three "things" the 433MHz Receiver, Transmitter and 4x20 Display
work together with any kind of serial drivers (like FullDuplexSerial, FullDuplexSerialPlus, Extended_FDSerial)
One of these objects are the base. Objects are *.SPIN-files that contain all parts of a program that belong to the object.
You DON'T have to change anything INSIDE the object
For using the FullDUplexSerialPlus-object them together with the 433MHz Receiver, Transmitter or LCD you write your own
code that calls parts of the code inside of the file FullDuplexSerialPlus.spin with suitable parameters
example
the 4x20 LCD works at baudrates 2400, 9600 or 19200 depending on DIP-Switchpositions
If switch them to both to own the 4x20 LCD will work on 19200 baud
Let's assume the LCD is connected with PIN no 16 of the propeller-chip
So then you call the start-method of the FullDUplexSerialPlus-object with the following parameters
xxx.start(0,16,0,19200)
The 433 MHz Receiver/Transmitter work even transparent. Whatever bitbanging you "feed in" it will be transmitted an received.
This means: to whatever kind of serial device you connect the transmitter/receiver as long as the voltage-levels match
with the Receiver/Transmitter the datatransmission works. Up to 19200 baud.
ATTENTION !
As all three are 5V-devices you need to insert a current-limiting resistor to prevent the propeller-chip from getting damaged !
The propeller-chip itself is a 3.3V device
see this thread HOW TO SAFELY INTERFACE A 5V SIGNAL TO THE PROPELLER?
I recommend using the FullDuplexSerialPlus-driver as this driver provides a lot of constants for the Parallax Serial Terminal PST.EXE
and a lot of methods to convert numbers to ASCII-strings etc.
This file is a little bit hided away.
You will find it here: C:\Program Files\Parallax Inc\Propeller Tool v1.2.6\Examples\PE Kit\6 - Objects Lab\FullDuplexSerialPlus.spin
best regards
Stefan
