Use SERIN/SEROUT and three wires -- one TX from BS2 to BS2px, one RX from BS2px to BS2, and a ground wire to connect the two boards.
Then program one as a 'slave' to listen most of the time until the 'master' tells it to respond.
Program the 'master' to query the 'slave' when it wants to transfer data.
Here is a small snippet that should help. This program uses SERIN (on·a BS2) and SEROUT (on a BS2px), both on PIN 10 and communicating at 9600 baud;·this is not a two way communication demo but could be converted to do so pretty easy.·Hopefully with this and·the other help above you can get your project up and running.
http://forums.parallax.com/showthread.php?p=849307
Let us know of the results,
Respectfully,
Joshua Donelson
www.parallax.com
