Cores Cores and...
CounterRotatingProps
[font=arial,]
The "world's first" 100-Core Processor: Tilera's TILE-Gx100
[/font]▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
www.nvidia.com/object/tesla_computing_solutions.html
The new Fermi chip will have 512 cores:
www.nvidia.com/object/fermi_architecture.html
Leon
Amateur radio callsign: G1HSM
Post Edited (Leon) : 10/26/2009 6:03:36 PM GMT
Leon> 240 cores ... 512 cores...
The concept of "Core" is probably as nebulous as RISC ( - so let's not go *there* [noparse]:)[/noparse])
Indeed, I've got one of the smaller nVidia boards with a 'big core' here for CUDA programming.
Had heard rumors of its bigger brother - thanks for the links, Leon.
Gads, Man, the fermi is KILLER !
- H
on ebay for a handful of cash. It was 1KB of nonvolatile RAM in the form of tiny donut magnets somehow weaved
into a sheet of colorful magnet wire on a PCB. There are too many things and not enough names for them.
BTW:Anybody know what a certain "Magnistor" that uniquely looks like a 1 Farad supercapacitor with
a circle of pins (like a guitar amp tube) on the bottom does? I have some, but no clue what for.
Probably older than the core memory, and definitely found in the same scrap heap. (I doubt
anyone currently living on earth has ever used one.)
Also,(giggle) there is something similar looking, but longer, for Tube Radios in Cars that converted 6 volts DC
to higher voltage AC, and it is called a "Vibrator", and I wouldn't doubt that some people may have used
them in place of the other device with the same name.
I remember using one of those vibrators over 50 years ago with a filament transformer to make a high voltage supply. My older brother was in the Merchant Navy and had several as spares for the inverter he used to power the hi-fi unit he used in his cabin from the DC supply.
Post Edited (Leon) : 10/27/2009 11:59:54 AM GMT
Apple Cores -> ferrite memory cores ->cpu cores ->... photon cores -> nano-braino cores? [noparse]:)[/noparse]
Instead of this:
The·Core Memory board·was free. The Quadro was $3000·
There are more ferrites than 240
Jim
Sounds similar to something used in in the ignition system of old radial aircraft engines - 'shower of sparks' or something like that...
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
