How to convert .brd to a gerber or other file? — Parallax Forums
MicrocontrolledMicrocontrolled Posts: 2,461
edited 2009-10-27 17:31 in General Discussion
I have just compleated a board for manufacture using Eagle Light and I cannot figure out how to output files on it for manufacture. Can someone help??
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
Want cheap wholesale electronic parts?
Transistor parts wholesale
  • T ChapT Chap Posts: 4,249
    edited 2009-10-25 21:44
    There are more and more plants now that will take your .brd file. Sunstone circuits will, I use them all the time and just send up the .brd.
    Basically in the cam section you pull up Gerber 247 and select the layers you want to create from the list. You will need to find out from the plant what files they want. Name the files appropriately. Bundle the whole folder of files into a zip. I am sure your plant has some instructions on this. Also the cadsoftusa.com is a great source for this stuff.
  • James LongJames Long Posts: 1,181
    edited 2009-10-25 21:46
    You must run a CAM file on the PCB to get output gerbers.
    The CAM must be setup for which gerbers are output, and how they are processed.
    We have a standard CAM file for gerber output if you need. It is based on a 2 layer board, with components only on top.
    I would need to get it off my other computer......but let me know if you want it.
    NOTE: to run a CAM you must be viewing any layer that the CAM is going to process. If the layer is not visible....the CAM will not process that layer.
    James L
    James L
    Partner/Designer
    Lil Brother SMT Assembly Services
    Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
    edited 2009-10-25 23:30
    I am using Advanced Circuits in Colorado. They will not accept my .brd file for there auto correct that checks your circuit before submitting it to there site.
    edited 2009-10-26 01:11
    Look In old 18 and less thread I uploaded cam file there
    propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
    Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
    edited 2009-10-26 01:51
    thanks!
  • metron9metron9 Posts: 1,100
    Advanced Circuits is very good, I buy from them. When you do get your gerber files output you can look at them using viewmate http://www.pentalogix.com/ The viewmaster program allows you to edit and save the files but is not free.
    It is ice to see the gerber files you produce so you know what they look like.
    Advanced sends you files you can look at as well when you submit your files.
    Think Inside the box first and if that doesn't work..
    Re-arrange what's inside the box then...
    Think outside the BOX!
