Is there an EasyBT object?
blittled
I'm wondering if there is any code for the EasyBT (Easy Blue Tooth) with the Propeller?
I'm using one with the Propeller System Module and have it working with the Serial demo and wanted to connect to my Boe Bot with an EB500. The EB500 sees the EasyBT using the lst command but does not connect to the EasyBT. This is probably because pairing is required with the EasyBT. I found in the EasyBT documentation that the security level can be changed so pairing is not required.
To reset the security level I have to put the EasyBT into command mode with a UART break. Can the fullduplexserial object do an UART break?
If there is no code for the control mode of the EasyBT once I get it figured out I'll post it on this thread and eventually in the obex. Thanks!
What electronics need - MORE POWER!!!!!!!
Post Edited (blittled) : 10/24/2009 10:29:17 PM GMT
