DS1302 day of year function — Parallax Forums
lfreezelfreeze Posts: 174
edited 2009-10-24 23:45 in BASIC Stamp
I need help with something I thought would be simple. I want to program the Stamp
And a DS1302 To calculate and display the day of the year, ·
Example:
················ January 1······· =·· day of year· 1
················ December 31· =· day· of year· 365
·I have connected the Stamp to a DS1302 and I am getting accurate Readings for the basic DS1302 functions.· I built a Select case statement ( below)· I calculated the number of days to the first of each month for the year in my select case statement, I then· added the date to each months total· example:
Month = February, Date =10 , day of year should equal 41
The result I get for the day of year using my select case statement· (10 + 31)· is· 47
I tried many various hex, dec manipulations (DIG) function, but couldn’t get it to work correctly.· Can anyone offer a solution to this?
The full program I am using is attached.
Thanks in advance for your help.
Larry
dayofyear···· VAR Word
SELECT month
·CASE=$01·············· ·····'January
·dayofyear=date
·CASE=$02········ ··········'February
·dayofyear=date· +31··· ·'$1f
·CASE =$03·············· ···'March
·dayofyear=date· +59··· '$3b
·CASE =$04·············· ··'April
·dayofyear=date· +90··· '$5a
·CASE =$05·············· ···'May
·dayofyear=date· +120·· '$79
·CASE =$06·············· ···'June
·dayofyear=date· +151·· '$97
·CASE =$07············· ····'July
·dayofyear=date· +181·· '$b5
·CASE =$08·············· ··'August
·dayofyear=date· +212·· '$d4
·CASE =$09·············· ··'September
·dayofyear=date· +243·· '$f3
·CASE =$10·············· 'October
·dayofyear=date· +273·· '$111
·CASE =$11·············· 'November
·dayofyear=date· +304·· '$130
·CASE =$12·············· 'December
·dayofyear=date· +334·· '$14e
ENDSELECT
    edited 2009-10-23 14:14
    lfreeze,
    "(10 + 31) is 47"
    Your adding a HEX value to a Decimal value.
    10 Hex = 16 Decimal .... 16 + 31 = 47
    Since the 'Date' is stored in what's called BCD (Binary Coded Decimal) you need to convert it to Decimal first before adding it to your offset.
    Try:
    dayofyear = (Date.NIB1 * 10 + Date.NIB0) + 31
    Beau Schwabe
    IC Layout Engineer
  • lfreezelfreeze Posts: 174
    edited 2009-10-23 16:41
    Thanks for your help Beau, I modified the program and it worked perfectly. A working version is attached.
    Larry
    edited 2009-10-23 18:48
    Hi Larry,
    That is a good clean approach. I'd recommend that the program make one calculation of
    then do the CASE's to add the constant factor to that. Just to save program space used by repeating the NIB calculation. Don't forget leap years!
    Here is an approach that I came up with that does it in one funny formula:
    ' enter with month and year in BCD
    MM=month.nib1*10+month.nib0
    YY=year.nib1*10+year.nib0
    dayofyear=MM-1*30+(MM/9+MM/2)-(MM max 3/3*(YY//4 max 1 +1))+ DD
    Tracy Allen
    www.emesystems.com
    edited 2009-10-23 20:31
    Tracy,
    I tried the formula you suggested, and I must be missing something. when I run the formula using
    todays date, I get a "day of year result" of 273. the calendar tells me I should be getting 296.· I like
    your suggestion of streamling the code and will proceed with it. Thanks for your response, and please
    tell me what I've got wrong with the formula.·· Here is the code I am using.
    Larry
    dayofyear··· VAR Word
    mm··········· ·VAR Byte
    yy············ ·VAR Byte
    dd············ ·VAR Byte
    mm=10
    dd =23
    yy =09
    '____________________________________________________________________________
    top:
    GOSUB TELLTIME··· 'GETS THE CURRENT DATE AND TIME
    MM=month.NIB1*10+month.NIB0
    YY=year.NIB1*10+year.NIB0
    dayofyear=MM-1*30+(MM/9+MM/2)-(MM MAX 3/3*(YY//4 MAX 1 +1))+ DD
    DEBUG "···· DAYOFYEAR = ", DEC3 dayofyear,"··· MONTH =· ",HEX2 month,"··· DATE = ",HEX2 date,CR,CR
    PAUSE 1000
    goto top
    edited 2009-10-23 22:52
    Hi Larry, I'm not sure quite where it went wrong. That snippet does not compile as written because month and year are not declared. Here is a rewrite that gives dayofyear=296 when you enter 10/23/09:
    ' {$STAMP BS2pe}
    ' {$PBASIC 2.5}
    dayofyear    VAR Word
    mm             VAR Byte
    yy              VAR Byte
    dd              VAR Byte
    top:
      DEBUG "enter mm/dd/yy:"
      DEBUGIN DEC mm,DEC dd, DEC2 yy
      dayofyear=mm-1*30+(mm/9+mm/2)-(mm MAX 3/3*(yy//4 MAX 1 +1))+ dd
      DEBUG CR," DayOfYear= ", DEC dayofyear,"    mm/dd/yy= ",DEC2 mm,"/",DEC2 dd,"/", DEC2 yy,CR,CR
      PAUSE 1000
    GOTO top
    Tracy Allen
    www.emesystems.com
    Post Edited (Tracy Allen) : 10/23/2009 10:57:37 PM GMT
    edited 2009-10-24 15:23
    Tracy Allen
    dayofyear=mm-1*30+(mm/9+mm/2)-(mm·MAX·3/3*(yy//4·MAX·1·+1))+·dd
    How would you work it back the other way
    Take 252 day which would be 09/09/09
    Can this be done
    ··Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
    Sam
    edited 2009-10-24 16:25
    Hi sam_sam_sam,
    I've done that reverse lookup with a LOOKDOWN for the month boundaries:
    ' {$STAMP BS2pe}
    ' {$PBASIC 2.5}
    mm   var  byte  ' month, (not BCD)
    dd   VAR  Byte  ' day, (not BCD)
    yy   VAR  Byte   ' year
    jd   VAR  Word  ' julian date in year, 0->365 or 366
    ly  VAR Bit     ' 1 if leap year, 0 if not
    xb  VAR bit     ' helper bit
    DO
        DEBUG "enter day of year, 1-365:"
        DEBUGIN DEC3 jd
        yy = 9   ' 2009 assumed
        ly=0  ' 2009 is not a leap year
        xb=jd MAX 60 / 60 * ly    ' helper for leap year
        LOOKDOWN jd-xb,<=[noparse][[/noparse]31,59,90,120,151,181,212,243,273,304,334,365],mm
        mm=mm+1
        dd=jd-(mm-1*30+(mm/9+mm/2)-(mm max 3/3*(2 - ly)))
        DEBUG CR," DayOfYear= ", DEC jd,"    mm/dd= ",DEC2 mm,"/",DEC2 dd,CR,CR
    LOOP
    Tracy Allen
    www.emesystems.com
    Post Edited (Tracy Allen) : 10/25/2009 3:45:32 PM GMT
    Tracy Allen
    Thanks for sharing that code with me
    Sam
