Basic Info
Hello
i am working on a project and wanted to know what are the good benifits of the propeller chip VS basic stamp i am looking for a few requirements
1. energy saver
2. east to code
3. works with parallax products
4. good support
i have a few basic stamp boards to work on my ideal but the basic stamp is a pain i need to do more than 1 thing at a time and cant do that with a basic stamp chip i feel like i wasted my money on it unless someone can tell me otherwise.
thanks in advance
1. energy saver
2. east to code
4. good support
thanks in advance
2) The Propeller can be programmed in Spin, C, or its assembly language. There's a Basic compiler (to assembly) in the works based on SX/B for the SX processor. There's a simple integer Basic interpreter available that's useful for experimentation and some simple, slow applications. There's a new graphical programming system called 12Blocks (www.12blocks.com) that produces Spin code and has an integrated debugging system (ViewPort ... also available from Parallax).
3) Most Parallax products designed for the Stamp will work with the Propeller. Some require a series resistor on the order of 2.2K or 1K in the I/O leads to protect the Propeller from a 5V output. Some new Parallax Propeller-based products like the Propeller Servo Controller and the StingRay's controller board have built-in 3.3V to 5V bidirectional level translators that allow them to be used with all of the 5V Parallax products. The Propeller Servo Controller can be used as a general purpose microcontroller by simply changing the software on-board.
4) The Basic Stamp has been around for years and has amassed a huge pile of tutorials, examples, worked projects, etc. The Propeller has only been around for a couple of years and has a few tutorials, but a lot of user contributed objects in the Propeller Object Exchange that can be directly used in your programs to manage all sorts of tasks and devices. There is a fast floating point package in the Object Exchange.
Post Edited (Mike Green) : 10/23/2009 5:02:22 AM GMT
