Is there a practical limit to how many 1-wire devices the Prop can handle on a
Ladies and Gentlemen,
it is my sincere hope to obtain data from about 30 digital thermometers of the 1-wire variety, specifically the DS18B20 (data sheet attached). For a long time I've been using Micah Dowty's Spin version of the 1-wire protocol, obex.parallax.com/objects/342/ , which has worked well for up to 6 devices but I know Micah had some sort of limitation built into his code, not to take more than 8 devices, I think. So I'm now wondering if there are practical limits to how many devices one can, or should, use with 1-wire.
In the data sheet on page 8, I see that if I reduce the resolution of my DS18B20s down to 10 bits, then I get a conversion time of no more than 189 ms per device. So at first glance I would say that 30 devices could give me updated information within every 6 seconds or thereabouts. But I'm guessing it's not so simple as that. I'm guessing there are other forces at work in the universe of which I am not aware and that hanging more devices on a 1-wire line does not result in total conversion requirements that are linear and simple-minded. I'm guessing there's some kind of exponential equation lurking around here somewhere. Furthermore, I'm guessing there are current-sinking issues of some sort to contend with. But despite all my poking around on the Maxim website, etc. I've not been able to find anything that tells me what sort of limitations to be aware of.
Anybody know? Anybody have some sort of rules of thumb or direct experiences with using about 30 1-wire devices on a single line?
thanks for your insights,
Mark
Mark
pdf
219K
Perhaps you could describe how you connect to the DS18B20s (same pcb, on other pcbs, how long are the wires, etc). Then we may be able to give you a better estimate.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
Here again the SX might be your answer. Depending on the precision and accuracy you need, you might be able to use simple thermistors or RTD's. Possibly even thermocouples. I believe an SX48 could probably measure 32 devices when using some unconventional approaches.
One can make quite an effective software AD converter with only a single pin in an SX, or with a Propeller for that matter, although my experience is with the SX.
As far as 1 wire temperature sensors are concerned, the limiting factor would likely be the current load when performing multiple conversions simultaneously. The communication overhead would be some 50 or so microsec per message, and those will need to be sequential.
Cheers
Peter (pjv)
30 DS18B20s is a relatively small network as these things go. You could have several times that if you follow the recommendations.
I'm guessing you mean these: www.maxim-ic.com/appnotes10.cfm/ac_pk/1 I was skimming through them but so far nothing has jumped out at me. I guess I'll keep looking through them orrrrrr...
Maybe I'll just go on that comment and hope for the best.
All 30 of the DS18B20s will be running along the edge of 2 separate PCBs, each 12 inches long, which are mounted end-to-end with their connections jump-wired to each other by very short pieces of wire. The Propeller master will most likely be mounted somewhere about 5 feet from those 2 PCBs. They all use the pull-up resistor method, not the parasitic version.
Well, you might be right. But everything I've done up to now has been Propeller-based and DS18B20s have been what all the proto-prototypes have been using, so this is supposed to "merely" expand upon some work I have done already. So I'm somewhat in the Prop groove right now and would shatter into a million arthritic pieces of glass if I had to start something new at this stage/my age.
thanks, you guys, I'll probably sleep on this tonight as it's getting late here...
sweet dreams,
Mark
Watching the world pass me by, one photon at a time.
