powering the stamp(Board of education) with 7.4V lipo
Can I power the BOE with a stamp with a 7.4v 2 cell lipo battery?
If so where can I connect the positive and negative terminals to ?
If you don't want to use either of those two choices, you could connect the positive end to Vin and the negative end to Ground. Be sure to use a fuse of some sort. If the battery becomes shorted, it could explode or catch fire. Use no bigger than a 1 Amp fuse.
The result of this is that the linear regulator (that three-pin device standing up) will run a little warm -- but this should not do any damage.
The only thing that could be damaged would be a servo (if you're using servos) if you leave the jumper set to "Vin", because servo's don't like anything over 7.5 volts.
Post Edited (Mike Green) : 11/2/2009 5:17:11 PM GMT
