Memory full
My program i growing and the EEPROM in my BS2 was full. I went out and got a BS2e which has more EEPROM space but when I check memory map the eeprom is still full. I start to find solution here in the forum and I found the Compiler Directives. I copied part of my program over to a new file added this line {$STAMP BS2e, CC-part2.bs2} But it does not work its like It can not see the other file or do I do something wrong here?
To make it simple did I take all Sub routines to the new file maybe that was wrong. Can any explain how it works with different files. I was reading the help file but no direct answers there
There is an interesting article that is available that might help with multi-slot programming;·it is in Nuts and Volts Volume 3, Article #87. You can refer to this column for some good tips for programming multi-slot controllers; however, if you can·post the code you currently have,·we can take a look·and offer some suggestions.
Nuts and Volts Volume 3:
http://www.parallax.com/Resources/NutsVoltsColumns/NutsVoltsVolume3/tabid/445/Default.aspx
I hope this helps,
Respectfully,
Joshua Donelson
www.parallax.com
