Interfacing VNH3SP30
I am trying to interface a Motor Driver chip, the VNH3SP30, does any one know how to get the 5V logic inputs for INA, INB and PWM etc to work with 3.3V on propeller.
The issue is the docs for the chip suggest a minimum logic high level of 3.25 volts and not the usual TTL 1.4V or CMOS 2.5V logic This seems touch and go for the 3.3V high output of the propeller.
Will a direct connection to the propellar work in this case ?
If not what is a good way to interafce this ?
The copious documents on the 3.3V to 5V Interfacing Issue on the forums and elsewhere ignore the issue when higher than CMOS High voltages are required.
I note there is no circuit for the Parralax HB-25 driver product that uses this chip, is that available ?
Seems there is also no documentation for this product ?
·http://forums.parallax.com/showthread.php?p=805489
The new Stingray robot uses bi-directional level translators:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/stingray/List/0/SortField/4/ProductID/601/Default.aspx
And the new Propeller based servo controller uses a TX0108 auto direction translator:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/PSC/List/0/SortField/4/ProductID/595/Default.aspx
Jim
Post Edited (hover1) : 10/22/2009 11:40:18 AM GMT
············ ············· +5V
······················ 3k3···· 1K
········ MC33887────┴──── prop pin
Post Edited (Timmoore) : 10/22/2009 4:41:28 PM GMT
