Smithy 3 in one lathe,Mill,Drillpress
My wife said i can buy one of these and i wondered if anyone has any experience with·this·brand or others. I plan to convert it to CNC control.
Since the machinest I hired to make my motormounts still has not done them, i decided it was time to learn how to do some of my own machining.
·http://www.smithy.com/product_home.php?cid=1&scid=22&pid=1010
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Be aware they are the entry points into very addictive hobbies/small business activities! On the business side, you have to remember that sometimes it is best to get (pay) someone to do these things while you carry on with other aspects of the project.
Cheers,
Tom Sisk
http://www.siskconsult.com
Not exactly glowing praise for those little machines, but it may be just elitist talk from "professional machinists".
Duffer
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
A metal cutting bandsaw is very useful too if you will be machining a lot of metal.
Tabletop Machining is a good book for those new to machining.
Rich H
Post Edited (W9GFO) : 10/22/2009 3:21:49 PM GMT
Eventually, I found a decent used Light Machines CNC mill and gave away the Sherline.
Anyway, regarding the Smithy, it looks a bit awkward to use — especially the drill press. I'd get a cheap benchtop drillpress from Harbor freight and look for a dedicated 3-axis mill. Pick up a copy of Digital Machinist magazine if you need some ideas. The lathe you can probably live without. I don't have one, occasionally want one, but get by without. It you do metal-working, though, a bandsaw is absolutely essential to prep stock for the mill. I got a cheap horizontal unit from Harbor freight, and it's served me well.
I still have not set it up...it's been weeks. A guy was going to show
me how to use it but he has not been over yet.
"Where am I? Where am I going? Why am I in a handbasket?"
Rich H
I didn't know you were into rocketry. I designed an alcohol/NOX injector a few years ago, but could never find a machinist that could make it (it required a 6 axis mill).
I was a partner in a CNC business since then, but had to go a different direction than my partner.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
Rich H
Rich H
Looking at the used bridgeports (even new series 1 machines) I think I would lose less money over 10 years than a cheap wannabe machine.
For the moment though, I am getting ahead of myself (I usually do) and then I step back and re evaluate the actual wants and needs and excitement of a big box (or skid) arriving on my shipping dock. Going to stay on the guy that promised my 5/16 shafts with a .125 keyway turned to a 1/4 inch at one end so I can mount my motors to by ball slides and make my own shureline version mill I can rout circuit boards and other stuff with. If that works out I may want to design small circuit board routing machines and then perhaps look at a bridgeport to make the parts.
Rich,
You are much deeper into liquid than I. I was more of a Ratt Works type of designer. I never wanted to mess with LOX, although NOX is actually more dangerous. But my design was not any where as big as your design. Is very interesting though.
James L
James L
Partner/Designer
My involvement in rocket stuff is what got me into machining. (trying to keep on topic)
Rich H
Sorry everybody for hijacking the thread......
It is hard to find a reasonable machine which works well.....and is also small.....
James L
EDIT:.....had to change my poor English.
James L
Partner/Designer
Post Edited (James Long) : 10/22/2009 10:42:27 PM GMT
Since nobody has come forth with any ideas on the other post SLA7078 I have spent another 100 bucks on the hobby cnc pro board that uses these chips so I can understand how they work. Reverse engineer it as they say.
Post Edited (metron9) : 10/22/2009 10:33:41 PM GMT
Nice avatar...the tiny13 is one of my
favorites for small projects, they are so cheap!
I use the tiny13, the 644 and the 168 all the time.
they are R8 compatible the same as me also we are going to convert to CNC to but they also have more power than me .. drop me a line if you want to talk I will try and help as much as I can .. And don't get roped into the well knock offs don't have support
my smithy had the AV motors go twice I finally paid to fix them myself , the caps went bad
Mike.D
