Simple IR detector?
Hi All,
I was hoping you could help me with a problem. I am new to BasicStamp and I'm learning as I go so bear with me. I am trying to build a simple IR detector using the IR LED transmitter and IR Receiver from Parallax. I'd like to have them facing each other and give me a yes or no whether something is in the way and blocking the IR transmitter signal. If I wanted it to turn on an LED when the beam was blocked, how would I do that?
Thank you ahead of time for your help,
Tim
Tim
IR Transmitter 350-00017
http://www.parallax.com/Portals/0/Downloads/docs/books/edu/Roboticsv2_2.pdf
http://www.parallax.com/Portals/0/Downloads/docs/prod/edu/WebApplied%20Sensors%20V2.0.pdf
Three good references that will answer most if not all of your questions.
- Stephen
