A really great Mosfet to use with the Prop... but can the Prop drive 20 of them
I've been using the Mosfet IRF3708 with great success (thanks to your generous help) on just a couple of circuits, but now I'm faced with running about 20 mosfets off the same Propeller and I'm wondering if the Prop can handle the required current needed to control so many gates. On the IRF3708 data sheet (attached), page 2 shows something called IGSS to be 200 nA. I presume this is all the current that the gate requires to switch. If so, then 20 mosfets should not be a problem for a single Propeller, I think. But I'm kinda stupid when it comes to reading data sheets, so I was wondering if I'm reading that correctly or if I'm totally off the mark in using IGSS to make this calculation???
thanks,
Mark
thanks,
Mark
Thanks, Phil,
I suspected it wouldn't be so simple as adding up the IGSS. I suppose what I could do is monitor the voltage drop across the current-limiting resistor that I'm using now and see what the voltage drop is across it, then from that figure out what the current draw is. With a 330 ohm current-limiting resistor going to the gate, the current will have to be something less than 10mA.
thanks,
Mark
